Delivering USB data transfer speeds of up to 480 Mbps, the COM-1440 features four downstream USB ports, along with two onboard SSD mezzanine sockets for up to 4GB of secure high-speed Flash memory. Notably, two of the product�s USB ports are enhanced to supply 2 Amps of drive for directly powering attached USB mass storage and other devices through the USB cable.
The new uDOC compatible sockets enable rugged high-performance, solid state storage with high throughput rates (20MB/sec read and 10MB/sec write) using USB 2.0, a modern design approach for advanced embedded systems. The two memory device sockets are connected in parallel with two of the external USB ports. When the two uDOC sockets are populated, one standard (500mA) USB port and one enhanced drive USB port are free for system expansion. Accessible as independent logical disks and available in extended temperature formats, uDOC encrypted solid state flash disk devices from M-Systems are available in capacities ranging from 64 to 2048MB each.
PRICING AND AVAILABILITY
This product is currently in stock and priced at $132/each in 100-unit quantities.
SPECIFICATIONS
� USB Ports: Four independent USB 2.0 downstream ports
� Current Drive: 2 standard 500mA drive USB ports, 2 enhanced ports with 2000mA drive capability
� USB Compliance: OHCI 1.0a and EHCI USB 0.95; Reverse Compatible with USB 1.1
� Operating Temperature: -40�C to +85�C
� Bus Architecture: PCI bus compliance with PCI Rev 2.2, 32-bit bus
� Transfer Speed Modes: high speed (480 Mb/s), full-speed (12 Mb/s) and low-speed (1.5 Mb/s).
� Physical Dimensions: 3.550" x 3.775" (PC/104-Plus)
� SSD Support: Two compatible sockets for secure high-speed Flash memory disks (up to 4,096MB total capacity); M-Systems uDOC disks sold separately
� OS Compatibility: Windows XP Embedded, CE, Linux, QNX, VxWorks, and other RTOSs
ABOUT PARVUS
Since 1983, Parvus Corporation has been a strategic systems engineering and development partner for aerospace, defense, transportation, and industrial OEMs. Specializing in the rapid design and production of turnkey embedded computing solutions for harsh environments, Parvus leverages extensive expertise in systems integration and a complete line of rugged PC/104, PC/104-Plus, and PCI-104 computer modules to ensure high reliability and accelerate time-to-market for its customers. Parvus is the US arm of the Eurotech Group, which has operations across Europe, North America and Asia.
Visit http://www.parvus.com or call 801.483.1533 for more information.
NOTE FOR EDITORS
A high-resolution photo of these products can be downloaded at http://www.parvus.com/News/MediaDownloads/
