8 instruments in 1 module !
Oct 05, 2016
The Multiple Instrument Station MIS4 provides you with all the instruments required for the test and measurement of electronic components and PCBs. This portable, USB driven module can be installed into an ABI USB Multilink Case or even into your existing PC! (please contact sales for details).
ABI’s SYSTEM 8 MIS4, along with the Ultimate software, is a faster and more economical solution than using traditional oscilloscope, metering and other bench test instruments, and can quickly produce the required Pass/Fail or other test and debug results.
The MIS 4 package comes complete with the TestFlow Manager, a step by step sequence generator that guides operators during fault-finding or test procedure processes. The TestFlow greatly reduces the risk of inaccurate measurements and automatically saves all test parameters for a final customised test report.
Digital Oscilloscope
  • 3 independent channels
  • 350MHz, 500MS/s per channel
  • 6 trigger sources
  • 28 automatic measurements
Arbitrary Waveform Generator
  • 2 independent channels, 14Bit resolution
  • 25MHz, 200MS/s
  • Variable clock for truly repetitive waveforms
  • Max combined output voltage ±10V
  • 6 standard wave shapes
  • Create and import your own
Universal Frequency Counter
  • 1 channel @1.1GHz +3 channels @350MHz (DSO)
  • Programmable trigger threshold
  • Sensitivity -21Bm @100kHz/- 1.2Bm @1.1GHz
Universal I/O
  • 8 fully programmable, independent channels
  • ±10V OUT @20mA, ±15V IN
  • 5 logic presets available
Ammeter
1 channel, isolated
DC, true RMS AC or AC+DC
±10V, 4 ½ digits, 20,000 Count
Voltmeter
2 channels, isolated
±500V, 4 ½ digits, 20,000 Count
Ohmmeter
1 channel
20MΩ, 4 ½ digits, 20,000 Count
Resistance, Continuity and Diode modes
Auxiliary Power Supply
  • 4 independent controlled channels
  • +12V -12V up to 100mA
  • +5V up to 1A, +3.3V up to 1A
Mar 24, 2009 -
Counterfeit IC's
Dec 02, 2008 -
SPOT THE IMPOSTER !!! If only fake ICs were as easy to spot...
8 instruments in 1 module ! news release has been viewed 536 times
Manufacturing Software
