  • Pickering Electronics with latest Reed Relays at Designcon USA 2015 Santa Clara Convention Center, January 28-29th, 2015 Booth # 529
Dec 01, 2014
Former-less Coil Winding
Reed-Relaymate
Reed-Relaymate
Pickering Electronics are Manufacturers of high quality Reed Relays for Instrumentation and Automatic Test Equipment (ATE), High voltage switching, Low thermal EMF, Direct drive from CMOS, RF switching and other specialist applications. Relays are available in Surface Mount, Single-in-Line (SIL), Dual-in-Line (DIL) and many other popular package styles.
Pickering Electronics’ Quality Assurance
Pickering manufactures Reed Relays for instrumentation applications using only the highest quality materials. We are certified to ISO 9001-2008 and audited by the British Standards Institution. Pickering relays are subjected to continuous inspection during the manufacturing process and after a strenuous thermal cycling routine are 100 percent tested for all operating parameters on Automatic Test Equipment (ATE) and other specialized equipment. All ATE test results are archived and used for Statistical Process Control.
Talking about Former-less Coil Winding
All Pickering Reed Relays are constructed using our SoftCenter™ technology, which uses a soft inner material to reduce stresses on the reed switch. In addition, contact life and more reliable contact resistance are achieved by our use of Former-Less Coil Winding. Pickering’s former-less coils are manufactured using a fully automated process that provides consistent output quality and repeatability. What advantages are given by using Former-Less Coil Winding?
Looking at the attached graphic you can see that former-less winding greatly increases the winding ‘window’, providing the following advantages:
1. A much higher magnetic drive level and better magnetic coupling as the smaller diameter of the inner turns are more efficient (more turns per Ohm).
2. The number of Ampere Turns (AT) is increased - Reed switches are usually rated in sensitivity by an Ampere Turn number, for example, an AT rating of 15AT is twice as sensitive as one with a 30AT.
3. Because the 30AT switch needs more magnetic drive there is much more ‘restoring force’, which is the ability to open when the coil drive is turned off. This in turn extends the working life of the reed switch many times.
At this year’s DesignCon show we feature amongst many other products at booth 529:
If you need Reed Relays for High Voltage applications customers should take a look at Pickering’s High Voltage Relays.
More information on above product  is available on our web site www.pickeringrelay.com
Pickering Electronics was formed in 1968 to design and manufacture high quality reed relays, intended principally for use in instrumentation and automatic test equipment.
Pickering Electronics offer an extensive range of high quality instrumentation grade reed relays designed for applications requiring the highest levels of performance and reliability. Through the experience of supporting the most demanding manufacturers of large ATE systems with high relay counts Pickering has refined its design, assembly and quality control methods to optimise its product range to this most challenging market.
Jun 29, 2017 -
Sep 22, 2016 -
Jun 27, 2016 -
Oct 05, 2015 -
Oct 05, 2015 -
Sep 08, 2015 -
Aug 18, 2015 -
Jul 08, 2015 -
Sep 18, 2014 -
Sep 17, 2014 -
Pickering Electronics with latest Reed Relays at Designcon USA 2015 Santa Clara Convention Center, January 28-29th, 2015 Booth # 529 news release has been viewed 1105 times
Facility Closure
Dual Lane Reflow Oven
