  • Universal Tooling For MPM AP Series and Ultraprint 2000 Printers Makes Setup Simple, Repeatable, Fast
Jul 13, 2001
New, versatile universal tooling for MPM AP Series and Ultraprint 2000 printers makes setup simple, repeatable, and fast. Designed to retrofit directly into most existing printers in these models, JNJ's UTP-1100 universal tooling is ideal for double-sided boards, because it features over 1,000 interchangeable support pin locations to effectively accommodate densely-populated circuit assemblies. Unlike magnetic-based tooling, there are alphanumeric characters assigned to the X and Y coordinate positions for the board supports, vacuum chucks, and board snuggers that can be recorded. This hard data can be used to record the actual board setup parameters, and can be reused for future setups. With this information, an operator can change the setup for a new board in 1 - 2 minutes. There is also an offline set up fixture that allows a board setup profile to be configured without interrupting current production runs.
Because the new UTP-1100 uses the same vacuum system and same mounting holes as the original MPM tooling plate, no drilling is required, and the retrofit can be completed on-site in about an hour. Eccentric and concentric board supports provide more potential support for densely-populated boards, and the UTP-1100 features both pneumatic board snuggers and fixed board snuggers with X and Y adjustment. Other features include adjustable vacuum chucks with thumb screw locks; 4 sets of vacuum side plates; position indicator strips along X and Y axis for exact support pin locating; 20 board supports; and more.
JNJ Industries is a leading provider of consumable products for many electronic/industrial applications. JNJ’s GlobalTech® line of environmentally responsible solvents and cleaning products serve a wide range of industries including high tech, automotive, aerospace, electronics, screen printing, and industrial manufacturing. For cleaning, maintenance, rework, and polishing, JNJ’s SmartWipes® line offers application-specific packaging and materials. For more information, visit www.jnj-industries.com. JNJ’s global headquarters are located in Franklin, Massachusetts, USA.
Jul 17, 2013 -
JNJ Industries' SmartHolder Keeps SmartWipes® Canisters Accessible
Jun 04, 2013 -
JNJ Industries Introduces OptiSmart® Flat Panel & Touch Screen Display Cleaner System
Jan 24, 2003 -
JNJ Industries Announces 30" Metal Squeegee Blades
Oct 30, 2001 -
AquaSonic® Features Closed Loop Recycling System
Jun 26, 2001 -
New AQS-3500 Manual Ultrasonic Stencil Cleaner
Apr 19, 2001 -
JNJ Industries Announces Major Expansion, Dynamic Growth
Universal Tooling For MPM AP Series and Ultraprint 2000 Printers Makes Setup Simple, Repeatable, Fast news release has been viewed 703 times
Non-heated dispensing system
