BEST Releases PCBVac(TM) -a Shop Vac for your PCB
Apr 02, 2014
New Product
BEST Inc Announces PCBVac™ a new “Shop Vac” for PCBs
Rolling Meadows, IL — BEST Inc. is pleased to announce the new PCBVac™ a shop vac for your PCB repair operation which can clean up both unwanted liquids and solids from a PCB. This adjustable, yet powerful vacuum cleaning system allows you to simply connect to clean, filtered shop air and then have a hand held tool in your hand to get around and underneath components. The Teflon™ heat resistant nozzles on the end of the handheld  are great for cleaning up molten solder and the nozzles can be trimmed to size thereby allowing different vacuum pressures to be developed on a PCB.
Use for this system are varied including liquids and solids. Solids can be solidified solder fines, scraped off solder mask or coatings. Liquids such as unreacted flux, flux cleaners, solvents and other liquids can be sucked off the surface of the board. This eliminates the problem of “pushing around” the dirt on a PCB instead getting it off the board.
Each PCBVac™ system consists of a controller with ON/OFF and vacuum adjustment, a quick disconnect plug and flex input tubing and filtration, a handheld vacuum applicator inclusive of 6 ft of flex hose and (5) tips which can be configured by the user. The hand piece has a trap system which can be cleaned out when particulates, solder or liquids get sucked up from a board.
“Customers will really like this versatile product for cleaning up flux residues, small scraped off particulates and for cleaning solutions on or out from underneath parts.” remarked Katy Radcliff, product manager of Best Inc.
The unit cost is $330 and is available for immediate shipment.
About Business Electronics Soldering Technologies (BEST)
Headquartered in Rolling Meadows, Illinois BEST is a supplier of PCB rework and repair services as well as tools for those services in the communications, computer, industrial, automotive, avionic and military sectors. In addition BEST is an master IPC-certified training center certifying students and instructors in J-STD-001, IPC-610 and IPC 7711 and 7721 material.
Contact: Katy Radcliff, Product Manager
BEST Inc
(847)-797-9250
www.solder.net
May 12, 2019 -
Custom SRT and Hot Air Nozzles
Oct 23, 2018 -
High mix Low Volume Technical Webinar
Aug 17, 2018 -
New Product Launched Component ID Poster for Electronics Training
Jun 15, 2018 -
Capabilities Video Launched
Mar 20, 2018 -
BEST Announces Availability of Custom Electronics Packaging
Nov 25, 2017 -
FREE IPC-A-610 and J-STD-001
Oct 03, 2017 -
New Sustainable J-STD-001 Soldering Kit
Oct 03, 2017 -
Mar 31, 2017 -
BEST Inc. Puts Semi-Automated Mass PCB Rework Process Online
Oct 25, 2016 -
BEST SMT Boot Camp Nov 29-Dec 1, 2016 Featuring Phil Zarrow
24 more news from BEST Inc. »
BEST Releases PCBVac(TM) -a Shop Vac for your PCB news release has been viewed 821 times
Capillary Underfill process
