Saelig Introduces Raspberry Pi-based Fanless CANbus Controller
Aug 21, 2015
Industrial Raspberry Pi controller from Saelig adds CANbus etc.
 Saelig Company, Inc. (Saelig) (www.saelig.com) announces the availability of the emPC-A/RPI - a compact, fanless embedded controller based on the Raspberry Pi 2 B board, but with Janz Tec add-ons to implement additional features needed for industrial applications. Intended for wall or DIN-rail mount, the emPC-A/RPI includes extra features that expand the usefulness of the Raspberry Pi computer, including a CANbus interface. The compact 24-pin multi-connector provides access to many of the emPC-A/RPI interfaces such as SPI, I2C, 8 x digital I/O lines, RS232/485, etc. Two USB interfaces are also available on the connector panel.
The compact (4.0” x 3.8” x 1.2”) and lightweight ( 0.9lb) emPC-A/RPI is powered by a 900MHz quad-core ARM Cortex-A7 BCM2836 processor with 1GB SDRAM. Built-in interfaces include: HDMI graphics, 10/100 Mbit/s Ethernet, 4 x USB 2.0, Micro SDcard socket, CAN, serial debug (9-pin D-SUB), an RS232/485 Serial port, RTC with battery backup, 4 x digital outputs, and  4 x digital inputs (isolated from logic). The serial port is implemented by a SC16IS740 UART and supports either RS232 or RS485 (link-selectable).  The CAN interface is implemented by an MCP2515 controller chip, and the CANbus signals support ISO 11898-2 (high speed), isolated from system logic. Input power requirements can accommodate a 9 – 32V supply.
The emPC-A/RPI comes standard with pre-installed Raspbian operating system software.  If the additional interfaces of the emPC-A/RPI (RTC, CAN, RS232/RS485) are required, then the Janz Tec emPC-A/RPI Raspbian-compatible driver package is also available. This enables the additional features of the emPC-A/RPI such as RTC, CAN, and RS232/RS485. The emPC-A/RPI is also available without software to allow the choice of an alternative Raspberry Pi 2 B compatible operating system.
The use of CODESYS runtime control system software is also possible for the emPC-A/RPI.  This is a soft PLC program created by 3S-Smart Software Solutions GmbH. Using this IEC 61131-3 programming system in combination with the Janz Tec emPC-A/RPI system makes it ideal for test and educational applications because the controller can make use of the additional interfaces the emPC-A/RPI offers, such as digital IO, CAN, RTC, and RS232/RS485.
Made in Europe by Janz Tec AG, a leading industrial control and CANbus manufacturer, the emPC-A/RPI is available now from Saelig Company, Inc., Janz Tec’s authorized North American distributor.
Mar 18, 2022 -
Mar 11, 2022 -
Feb 16, 2021 -
Dec 03, 2020 -
Oct 23, 2020 -
Oct 14, 2020 -
Jun 30, 2020 -
May 28, 2020 -
May 26, 2020 -
May 15, 2020 -
Saelig Introduces Raspberry Pi-based Fanless CANbus Controller news release has been viewed 1369 times
Dual Lane Reflow Oven
