  • Kyzen to Highlight METALNOX® M6960 and METALNOX® M6330 at CMTS 2009
Sep 18, 2009
NASHVILLE — September 2009 — Kyzen, a world leading provider of environmentally responsible precision cleaning products for electronics and high-technology manufacturing operations, announces that it will feature METALNOX® M6960 and METALNOX® M6330 in booth 33007 at the upcoming Canadian Manufacturing Technology Show, scheduled to take place October 19-22, 2009 at the Direct Energy Centre in Toronto, ON, Canada.
METALNOX® M6960 is an industrial vapor cleaning solvent designed for use in standard vapor degreasing equipment as a drop-in replacement for chlorinated solvents. M6960 is used as received for the removal of typical industrial soils including stamping, drawing, forming and hydraulic oils, buffing compounds, greases, and shop dirt from ferrous and non-ferrous substrates.
METALNOX® M6960 has superior performance characteristics over other brominated-based cleaning solvents due to its unique stabilizer package that allows for longer bath life.
METALNOX® M6960 concentration should be monitored and maintained on a routine and regular basis depending on tank use. Best results are obtained with an Acid Acceptance Test Kit available from Kyzen.
Kyzen® Booster 6 is available for sump adjustment as required for prolonged bath life.
METALNOX® M6330 is a high alkaline aqueous solution designed to clean and brighten a wide variety of metal parts. M6330 will provide long-term corrosion protection on ferrous and copper based alloys, including brass and bronze. M6330 is intended to be diluted for use in spray or immersion systems.
METALNOX® M6330 is particularly effective in removing heavy greases and oils found in typical CNC machining operations. M6330 will not discolor sensitive metals such as brass and other copper based alloys. Aluminum alloys should be tested to determine compatibility.
A non-flammable, corrosive, low VOC aqueous solution, METALNOX® M6330 has proven compatible with most materials of construction used in industrial parts cleaning systems and processes. METALNOX® M6330 contains no CFCs or HAPs.
METALNOX® M6960 is available in 50 and 550 lb containers. METALNOX® M6330 is available in one, five, and 55 gallon containers.
Kyzen® and METALNOX® are registered trademarks in the United States of Kyzen Corporation.
Kyzen is a leading supplier of precision cleaning chemistries to the worldwide electronics, metal finishing, medical, semiconductor, and optical industries. Founded in 1990, Kyzen offers superior cleaning chemistries, technical support, application and analytical services throughout the world. Kyzen has won numerous industry awards for their exceptional products and all products are RoHS compliant. For more information, visit http://www.kyzen.com.
May 18, 2022 -
KYZEN to Discuss Precision Metal Cleaners at MECSPE 2022
May 18, 2022 -
KYZEN to Present Free Clean and Green Seminar – New and Advanced Cleaning Technologies
May 18, 2022 -
Meet the KYZEN Clean Team in Mexico at SMTA Juarez and SMTA Tijuana
May 05, 2022 -
Ethan Mueller Named to Products Finishing's Prestigious 40 Under 40 Award Program
May 05, 2022 -
KYZEN to Discuss 3D Printing Process Resin Cleaners at RAPID + TCT
Apr 28, 2022 -
Tom Forsythe to Present at the Electronics in Harsh Environments Conference
Apr 20, 2022 -
Let KYZEN steer you to safe cleaning alternatives to replace traditional solvents!
Apr 20, 2022 -
Catch the KYZEN Clean Team at Three SMTA Expos in May
Apr 13, 2022 -
KYZEN to Introduce Its New Aqueous Cleaning Solution at SMTconnect
Apr 06, 2022 -
KYZEN to inform of solvent replacement chemistries offered for the Southern New England Design-2-Part Show
533 more news from KYZEN Corporation »
Kyzen to Highlight METALNOX® M6960 and METALNOX® M6330 at CMTS 2009 news release has been viewed 558 times
