  • Kyzen to Highlight METALNOX® M6330 and METALNOX® M6319 at EASTEC 2010
May 11, 2010
NASHVILLE — Kyzen, a world leading provider of environmentally responsible cleaning products for high reliability and high-technology manufacturing operations, will feature METALNOX® M6330 and METALNOX® M6319 in booth 3021 at the upcoming EASTEC Advanced Productivity Exhibition, scheduled to take place May 25-27, 2010 at the Eastern States Exposition Grounds in West Springfield, MA.
METALNOX® M6330 is a high alkaline aqueous solution designed to clean and brighten a wide variety of metal parts. M6330 will provide long-term corrosion protection on ferrous and copper based alloys, including brass and bronze. M6330 is intended to be diluted for use in spray or immersion systems.
METALNOX® M6330 is particularly effective in removing heavy greases and oils found in typical CNC machining operations. M6330 will not discolor sensitive metals such as brass and other copper based alloys. Aluminum alloys should be tested to determine compatibility.
A non-flammable, corrosive, low VOC aqueous solution, METALNOX® M6330 has proven compatible with most materials of construction used in industrial parts cleaning systems and processes. METALNOX® M6330 contains no CFCs or HAPs.
METALNOX® M6319 is a heavy-duty aqueous high alkaline all-purpose cleaner. It is an aqueous blend of detergents, alkalinity builders, conditioners, and organic and inorganic inhibitors designed for heavy-duty cleaning of oils, waxes, grease, drawing oils, machining oils, fingerprints, hydraulic fluids, road dirt, carbonized oils, petrolatum and shop dirt while being relatively safe to use on most alloys.
M6319 is easy to use, and is diluted further with water as required to remove the soils involved. To prevent flash rusting of ferrous parts, one to three percent of M6319 or an inhibitor may be added to all rinse stages.
The cleaner is low foaming, non-phosphated, and is safe on magnesium as well as ferrous and copper alloys. It features trace silicates, prevents flash rust, and has no HAPs, CFCs or SARA 313s. Additionally, M6319 is low VOC and can be used in both spray and immersion systems.
M6319 is multi-metal safe for use on yellow metals including copper, bronze and brass, some aluminum alloys, iron, steel, and composites in addition to most precious metals, plastics and rubbers.
METALNOX® M6330 and M6319 are available in one, five, and 55 gallon containers.
Kyzen® and METALNOX® are registered trademarks in the United States of Kyzen Corporation.
Kyzen is a leading supplier of precision cleaning chemistries to the worldwide electronics, metal finishing, medical, semiconductor, and optical industries. Founded in 1990, Kyzen offers superior cleaning chemistries, technical support, application and analytical services throughout the world. Kyzen has won numerous industry awards for their exceptional products and all products are RoHS compliant. For more information, visit http://www.kyzen.com.
May 18, 2022 -
KYZEN to Discuss Precision Metal Cleaners at MECSPE 2022
May 18, 2022 -
KYZEN to Present Free Clean and Green Seminar – New and Advanced Cleaning Technologies
May 18, 2022 -
Meet the KYZEN Clean Team in Mexico at SMTA Juarez and SMTA Tijuana
May 05, 2022 -
Ethan Mueller Named to Products Finishing's Prestigious 40 Under 40 Award Program
May 05, 2022 -
KYZEN to Discuss 3D Printing Process Resin Cleaners at RAPID + TCT
Apr 28, 2022 -
Tom Forsythe to Present at the Electronics in Harsh Environments Conference
Apr 20, 2022 -
Let KYZEN steer you to safe cleaning alternatives to replace traditional solvents!
Apr 20, 2022 -
Catch the KYZEN Clean Team at Three SMTA Expos in May
Apr 13, 2022 -
KYZEN to Introduce Its New Aqueous Cleaning Solution at SMTconnect
Apr 06, 2022 -
KYZEN to inform of solvent replacement chemistries offered for the Southern New England Design-2-Part Show
533 more news from KYZEN Corporation »
Kyzen to Highlight METALNOX® M6330 and METALNOX® M6319 at EASTEC 2010 news release has been viewed 617 times
Dual Lane Reflow Oven
