  • Indium Corporation Features Heat-Spring® for LED Manufacturing at Strategies in Light
Feb 11, 2016
Indium Corporation will feature Heat-Spring®, a compressible, recyclable, metal thermal interface material, at Strategies in Light on March 1-3 in Santa Clara, Calif.
Indium Corporation’s Heat-Spring® is an interface that provides 86 W/mK of thermal conductivity using a pressure range of only 35-100+ psi.
Heat-Spring® helps Avoid the Void™ in high-power LEDs due to its superior conductivity, ease of use, and improved performance over time as compared to thermal grease alternatives. In addition, Heat-Spring® will not bake out or pump out, thus eliminating the air voids left by inferior greases that can result in thermal failures.
Heat-Spring® is reclaimable and recyclable, and is packaged in custom trays or tape & reel.
Heat-Spring® metal thermal interface material is just one of a wide range of Indium Corporation products for the LED assembly industry – from PCB assembly to die-attach to technology-enabling TIMs – which combine superior performance with ease of placement. This reduces cost, increases first-pass yields, reduces field failures, and optimizes profits.
To learn more about on Heat-Spring®, visit www.indium.com/thermal-interface-materials/heat-spring or visit Indium Corporation at booth 110.
Indium Corporation is a premier materials manufacturer and supplier to the global electronics, semiconductor, thin-film, thermal management, and solar markets. Products include solders and fluxes; brazes; thermal interface materials; sputtering targets; indium, gallium, germanium, and tin metals and inorganic compounds; and NanoFoil®. Founded in 1934, Indium has global technical support and factories located in China, Malaysia, Singapore, South Korea, the United Kingdom, and the USA.
For more information about Indium Corporation, visit www.indium.com or email abrown@indium.com. You can also follow our experts, From One Engineer To Another® (#FOETA), at www.facebook.com/indium or @IndiumCorp.
May 05, 2022 -
Indium Corporation, KATEK to Present Joint Process Development at SMTconnect
Apr 28, 2022 -
Indium Corporation Experts to Present at PCIM e-Mobility Forum
Apr 28, 2022 -
Indium Corporation Expert to Present at Electronic Components and Technology Conference
Apr 28, 2022 -
Indium Corporation Expert to Present at SiP Conference China
Apr 20, 2022 -
Indium Corporation to Present on e-Mobility at SMTA Michigan
Apr 20, 2022 -
Indium Corporation Introduces New Adhesive Solution for Semiconductor Applications at PCIM Europe
Apr 13, 2022 -
Indium Corporation's Dr. Ron Lasky to Present on Design of Experiments in Upcoming Webinar
Apr 13, 2022 -
Indium Corporation President to Deliver TestConX Keynote on Materials Science Innovations
Apr 06, 2022 -
Indium Corporation's Dr. HongWen Zhang to Present InSIDER Series Webinar
Apr 06, 2022 -
Sixteen Indium Corporation¬ Experts Certified by SMTA
346 more news from Indium Corporation »
Indium Corporation Features Heat-Spring® for LED Manufacturing at Strategies in Light news release has been viewed 676 times
MSD Dry Cabinets
