The MediCoat II is the next generation of Sono-Tek�s MediCoat stent coating system for coating arterial stents with polymers containing anti-restinosis drugs. The MediCoat II offers the same cutting-edge precision stent coating features that have made Sono-Tek the industry�s leader in producing high-quality stent coatings with expanded features and higher volume production capabilities. The system incorporates Sono-Tek�s MicroMist� ultrasonic nozzle, which produces a very thin, precise, straight spray pattern (with a diameter of 0.010 - 0.030"), and the company�s ultra-low flow AccuFlow� liquid delivery system.
Customers have the option of attaching a custom stent holding device onto the rotating mandrels or using Sono-Tek provided mandrels. The stents are loaded onto the mandrels and the cassette is inserted into the load chamber. The extend/retract shaft picks up each stent from the cassette and delivers it to the sealed process chamber for spraying. Stents are rotated at a fixed speed, controlled by the user. The stent moves horizontally side-to-side beneath the target area. The number of horizontal passes made is programmable.
A low-velocity exhaust maintains a negative air pressure to assure that any unwanted mist beyond the target area is removed. The system's unique design allows for safe and convenient access to the stent loading and unloading area. Large, unobstructed viewing windows and high-intensity internal LED lighting allow for easy observation.
With integrated controls for process parameters, liquid delivery and stent movement, the MediCoat II stent coating system provides a complete solution for developing a stent coating process and moderate volume production.
About Sono-Tek Corporation
Sono-Tek is the world leader in the development and application of ultrasonic atomization technology. Compared to conventional pressure spraying methods, the company�s ultrasonic nozzles reduce liquid usage, waste, and environmental impact while achieving much more precise, uniform, thin film coatings with no clogging. For more information, visit the company at http://www.sono-tek.com.
