  • Everett Charles Technologies to Feature Lead-Free POGO� Contacts at APEX 2008
Mar 13, 2008
Pomona, CA - March 2008 - The Contacts Product Group (CPG) of Everett Charles Technologies (ECT) and atg Test Systems announces that it will exhibit LFRE, its Lead-Free POGO Contacts, in booth 1383 at the upcoming APEX 2008 conference and exhibition, scheduled to take place April 1-3, 2008, in Las Vegas.
Lead-free solder can cause many circuit testing problems. It has a higher reflow temperature, which can result in harder and stickier solder flux resin and a thicker, harder oxide layer. This thicker layer of resin and oxide is more difficult to penetrate and increases wear on the pogo pin. Additionally, lead-free solder resin and oxides can increase debris transfer to spring probes. These are many of the issues found in OSP and no-clean applications. As a result, ECT has developed the Lead-Free POGO Series, a new test probe series, specifically designed to solve these problems.
ECT�s new lead-free probe line incorporates numerous features that will significantly reduce the issues that arise when switching to lead-free solder as well as those contact issues that arise with OSP and no-clean solder flux.
New Proprietary Plating � The new lead-free probe incorporates a new harder and slicker plating that not only resists wear but also reduces solder and debris transfer.
Higher Preload � All of the new lead-free probes incorporate higher preloads to reduce spring force variation with board flex and increase the initial impact penetration, resulting in higher first pass yields.
PogoPlus Bias Ball Design � The PogoPlus internal bias ball design guarantees uninterrupted electrical contact with the probe sidewall, virtually eliminating probe-related false opens.
Range of Spring Force Choices � Compared to competitors� products, which offer limited spring force options, ECT�s LFRE Pogos are available in a variety of spring force choices in 100, 75 and 50 mil centers.
Spring Life � All of ECT�s LFRE probes have a spring fatigue life that surpasses 500,000 cycles. Competitors� lead-free products may increase preload but dramatically lower cycle life, in some cases, at or below 50,000 cycles.
Pointing Accuracy � ECT�s new lead-free probe incorporates a double roll close, which offers the industry�s best pointing accuracy. Increased pointing accuracy is beneficial when using lead-free solder and/or no-clean because the probe is less likely to touch the edge of the pad where the solder flux accumulates.
A variety of LFRE tip styles give users the flexibility to meet application needs. Additional benefits include probe tips, manufactured with ECT�s MicroSharp� technology, offer the ultimate in long-lasting tip sharpness and contact integrity; a double-roll close offers the industry�s best pointing accuracy, helping users hit the smallest test targets with high repeatability; a shorter plunger permits more spring volume, higher spring force and longer spring life; and ECT�s precious metal plating process, together with enhanced bias contact, provides highly repeatable conductivity.
Everett Charles Technologies, a Dover Corporation company, is a leading manufacturer of electrical test products and services, including semiconductor test products, bare-board automatic test systems, POGO� test contacts, backplane and loaded PCB test fixtures. Corporate manufacturing, service, and support facilities are ISO registered with locations in the United States, Europe and Asia. The company has been awarded numerous patents and participates actively in developing industry standards. Additional information is available at http://www.ectinfo.com.
Dec 12, 2017 -
ECT’s Switch Probes: Cost-Efficient Solutions for Testing Electronic Assemblies
Apr 23, 2014 -
Everett Charles Technologies Brings the Latest Advances in Electrical Testing to DMEDS
Jan 14, 2014 -
ECT to Introduce High-Performance Radial Connectors at ATX/MD&M West
Jan 07, 2014 -
ECT Releases High-Performance Radial Connectors
Nov 20, 2013 -
ECT Offers ZIP® Z0 and Z1 Contacts in HyperCoreTM Base Material
Oct 11, 2013 -
ECT to Showcase Electrical Test Products and Services at Productronica
Sep 17, 2013 -
ECT Technical Expert to Discuss Breakthrough PCBA Test Probe Technologies at SMTAI 2013
Sep 12, 2013 -
ECT to Bring Compliant Connector Solutions to SMTAI 2013
Aug 12, 2013 -
New Compliant Connector Solutions from ECT at ITC 2013
Mar 29, 2013 -
ECT to Exhibit at the Del Mar Electronics & Design Show
63 more news from Everett Charles Technologies »
Everett Charles Technologies to Feature Lead-Free POGO� Contacts at APEX 2008 news release has been viewed 609 times
Benchtop Fluid Dispenser
 Reflow System
