PCIexpress PMC Carrier
May 19, 2008
FOR IMMEDIATE RELEASE MAY 13, 2008
Dynamic Engineering
The Embedded Solution Center - (Santa Cruz, CA)
PCIeBPMCx1 by Dynamic Engineering
PCIexpress is starting to show up in more and more PC�s. Please pass this information along to your engineers and purchasing departments. Dynamic Engineering carries the PCIexpress carriers and we highly recommend ordering one today to familiarize yourself with the new platform
Storefront: http://dyneng.com/shopsite_sc/store/html/page11.html
I can help you with any questions you might have, provide a quote, technical assistance and order placement.
dedra@dyneng.com ~Dedra
PCIeBPMCX1 - PCIe [Express] to PMC Adapter / Carrier
Shown w/ zero slot fans in both positions. Fans avail. in; either, both, or neither position
http://www.dyneng.com/pciebpmcx1.html
Use your PMC with a newer style PC. The new PC's have PCI Express connectors, many times eliminating PCI Slots. The PCIeBPMCX1 ( PCIe Bridge PMC 1 slot) adapter / carrier converter card provides the ability to install one PMC card into a standard PCIe (Express) 4 lane slot. Suitable for PCI or PCI-X operation with the PMC; 32 bit or 64 bit data and 33, 66, 100 or 133 MHz. clock. Auto selected or switch programmable speeds. The bridge can operate with 1, 2, 3, or 4 lanes active and can be installed into slots with more than 4 lanes if desired. "Dynamic Data Sheet" available at: http://www.dyneng.com/pciebpmcx1.html
v PCIe and PMC Compliant design
v 4 lane - PCI/PCI-X speed
v LED's for status: power, PCIe lane, and PMC installed
v Tsi384 bridge for higher performance than PEX based designs
v 32 or 64 bit operation at 33, 66, 100 or 133 MHz.
v DMA, and Interrupts supported
v Matched length, differentially routed, impedance controlled rear IO from Pn4
v Local power supplies using +12V from PCIe connector. �12(1A+), 5(10A), 3.3(10A) supplied to PMC
v Zero Slot Fan options using the thickness of the PCB plus special low profile fans to reduce the rear dimension to the legal PCI height.
v Front side clearance is fully compliant with the carrier height requirement on slot 2.
v Need more than 64 watts � request the additional power cable
Contact: Dynamic Engineering 150 DuBois St #C Santa Cruz, CA 95060 831-457-8891 Fax 831-457-4793 dedra@dyneng.com http://www.dyneng.com
Need customized features? Email you requirements to dedra@dyneng.com
Dynamic Engineering has a multitude of solutions covering different architectures and mezzanine types. With most architectures you have a choice with carriers for cPCI, PCI, PCIe, VME, PCI-104, and other buses for both PMC and IP mezzanine modules. Usually your choice is based on other system constraints as both the PMC and IP can provide the IO you require. Dynamic Engineering is an expert with embedded solutions and can assist in your decision-making regarding architecture and other trade-offs. Dynamic Engineering has carriers for IP and PMC modules for most architectures, and is continually adding more based on customer requests.
I can help you with any questions you might have, provide a quote, technical assistance and order placement dedra@dyneng.com ~Dedra
Dedra Lakely-Bennett
Sales & Marketing Manager
Dynamic Engineering
150 Dubois St. Suite C
831.457.8891 Phone
831.457.4793 Fax
dedra@dyneng.com
Storefront: http://dyneng.com/shopsite_sc/store/html/index.html
The greatest compliment to us are your referrals!
Please pass my contact information to your colleagues, co-workers and associates
or forward me their contact details so they too can benefit from our services and products!
Aug 21, 2007 -
Dynamic Engineering announces rugged PC104p Chassis
Dec 14, 2001 -
PMC4U -4 UART channels with SCC
Dec 14, 2001 -
PCI card with 8 channels of LVDS input (8R) digital filtering and storage. "Scatter gather" DMA data transfer by Dynamic Engineering
PCIexpress PMC Carrier news release has been viewed 581 times
Large PCB Dispensing System
