GPD Global to Demonstrate PCD Technology at SEMICON West 2011
Jun 13, 2011
GPD’s PCD Dispensing provides next-generation volumetric dispensing and is compatible with materials used in electronics assembly.
GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix and R&D production will demonstrate its award-winning Positive Cavity Displacement (PCD) Dispensing in Booth #6186 in the North Hall at the upcoming SEMICON West, scheduled to take place July 12-14, 2011 at the Moscone Center in San Francisco.
GPD also will display the PCD Technology on its MAX Series platform. MAX Series dispensing systems offer high accuracy, precision dispensing over a wide range of applications. The MAX Series platforms are ideal for die attach, underfill, MEMS, micro-volume conductive adhesive and paste applications.
For more information about GPD Global’s PCD Dispensing, stop by Booth #6186 in the North Hall at the show or visit www.gpd-global.com.
Dec 17, 2019 -
Jan 09, 2019 -
Oct 08, 2018 -
Sep 06, 2018 -
Feb 12, 2018 -
Nov 07, 2017 -
Oct 02, 2017 -
Sep 07, 2017 -
Aug 19, 2017 -
Jul 10, 2017 -
GPD Global to Demonstrate PCD Technology at SEMICON West 2011 news release has been viewed 752 times
