GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix and R&D production will debut its Positive Cavity Displacement (PCD) 'H' Series high-resolution pumps in Booth #1849 at the upcoming Assembly & Automation Technology Expo, scheduled to take place September 20-22, 2011 at McCormick Place North in Chicago, IL.
GPD also will display the PCD Dispensing with a Syringe Mixing System that keeps fluids such as LED encapsulants with phosphor evenly mixed before they are dispensed.
