GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix and R&D production, will showcase its Positive Cavity Displacement (PCD) 'H' Series high-resolution pumps in Booth #439 at the upcoming IMAPS 44th International Symposium on Microelectronics, scheduled to take place October 11-13, 2011 at the Long Beach Convention Center in Long Beach, CA.
GPD also will demonstrate the PCD and MicroDot technologies on its MAX Series platform. MAX Series dispensing systems offer high accuracy, precision dispensing over a wide range of applications. The MAX Series platforms are ideal for die attach, underfill, MEMS, micro-volume conductive adhesive and paste applications. Max Series equipped with Micro-volume technology enables dispensing for 0201 components as well as die attach adhesives. Further expanding the Max Series capabilities with the continuously volumetric PCD dispense pump yields outstanding results with underfills, encapsulation and LED applications.
