  • GPD Global to Highlight PCD ‘H’ Series at SMTA International 2011
Sep 21, 2011
In side-by-side tests, PCD significantly improved throughput and lowered cycle times compared with auger and jetting dispense methods.
GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix and R&D production will showcase its Positive Cavity Displacement (PCD) ‘H’ Series high resolution pumps in Booth #133 at the upcoming SMTA International Conference & Exhibition, scheduled to take place October 18-19, 2011 at the Fort Worth Convention Center in Fort Worth, TX.
GPD also will demonstrate the PCD and MicroDot technologies on its MAX Series platform. MAX Series dispensing systems offer high accuracy, precision dispensing over a wide range of applications. The MAX Series platforms are ideal for die attach, underfill, MEMS, micro-volume conductive adhesive and paste applications.
Dec 17, 2019 -
Jan 09, 2019 -
Oct 08, 2018 -
Sep 06, 2018 -
Feb 12, 2018 -
Nov 07, 2017 -
Oct 02, 2017 -
Sep 07, 2017 -
Aug 19, 2017 -
Jul 10, 2017 -
GPD Global to Highlight PCD ‘H’ Series at SMTA International 2011 news release has been viewed 833 times
Fluid Dispensers
