  • GPD Global to Demonstrate New PCD 'H' Series at the 2012 IPC APEX Expo
Jan 23, 2012
GPD’s PCD Dispensing provides next-generation volumetric dispensing and is compatible with materials used in electronics assembly such as epoxies, thermal greases, underfills, oils, silicones and UV encapsulants, as well as materials outside of the electronics industry.
GPD Global, a manufacturer of precision fluid dispensing systems for high-volume 24/7, low-volume/high-mix and R&D production, will showcase its Positive Cavity Displacement (PCD) ‘H’ Series high-resolution pumps in Booth #2535 at the upcoming IPC APEX Expo, scheduled to take place February 28 - March 1, 2012 at the San Diego Convention Center in California.
GPD's PCD Dispensing provides next-generation volumetric dispensing and is compatible with materials used in electronics assembly such as epoxies, thermal greases, underfills, oils, silicones and UV encapsulants, as well as materials outside of the electronics industry. PCD Technology is designed for GPD Global platforms and may be used with other robots or tabletop operations with an easy-to-use tabletop controller.
GPD also will demonstrate the PCD and MicroDot technologies on its MAX Series platform. MAX Series dispensing systems offer high accuracy, precision dispensing over a wide range of applications. The MAX Series platforms are ideal for die attach, underfill, MEMS, micro-volume conductive adhesive and paste applications. Max Series equipped with Micro-volume technology enables dispensing for 0201 components as well as die attach adhesives.  Further expanding the Max Series capabilities with the continuously volumetric PCD dispense pump yields outstanding results with underfills, encapsulation and LED applications.
Dec 17, 2019 -
Jan 09, 2019 -
Oct 08, 2018 -
Sep 06, 2018 -
Feb 12, 2018 -
Nov 07, 2017 -
Oct 02, 2017 -
Sep 07, 2017 -
Aug 19, 2017 -
Jul 10, 2017 -
GPD Global to Demonstrate New PCD 'H' Series at the 2012 IPC APEX Expo news release has been viewed 699 times
Fluid Dispensers
