Advanced pump technologies available for retrofitting include: True Volumetric Pump, Precision Auger Pump, and Simplified Jetting Pump.
GPD Global's True Volumetric Pump is based on Progressive Cavity Dispense Technology. It accommodates a wide range of fluid viscosities - from water to mid-viscosity (65,000 cps) pastes. With a completely sealed system, these pumps do not drip nor drool. Volumetric pumps ensure the success of applications like underfill, LED encapsulation, solder mask, silicones, conductive ink, conformal coatings, and more. Three PCD pump models are available for integration into your system with small or large volume requirements. The smallest model dispenses volumes down to 0.5 μl, while the largest model dispenses at rates up to 16 ml/min. With the ability to program the controller in terms of volume or on/off mode, process set up and integration are a snap. Retrofit a Volumetric PCD Pump into your system to simplify the dispense process as well as improve throughput and yield.
Precision Auger Pump Integration provides your process development with a wide range of functionality. The advanced Precision Auger Pump expands solder paste dispensing to include 01005 with our newest auger design. With wetted parts machined from carbide, the auger/cartridge assemblies can withstand abrasive thermal pastes and damming fluids. With an intuitive touch screen controller that incorporates closed loop motion control, programming the pump and obtaining reliable dispensing has never been easier. This auger pump guarantees success when dispensing these fluids: abrasive thermal gel, conductive adhesive, dam and fill, gasketing, and more. Retrofit this outstanding auger technology into your platform to increase productivity.
The NCM5000 Jetting Pump simplifies jetting to its basic elements: hammer, pin, and nozzle. Only the pin and nozzle are wetted. This translates into easy set up, cleaning, and operation. The pump can be disassembled for cleaning in a matter of seconds. The drive system, being pneumatic, is designed for reliable, high speed operation, and can be serviced in the field when required. Wavy or uneven product surfaces do not affect the jetting pump because dispensing is typically performed 2 to 3 mm above the surface. By eliminating z axis motion and incorporating high speed pump operation, throughput is greatly increased. The NCM5000 is compatible with a wide range of fluids: UV curables, SMT glue, Underfills, LED encapsulants, and more. The NCM5000 Jetting Pump is now available for integration into your system for more effective dispensing.
Revive your existing dispense platform by retrofitting a cutting edge dispense pump. This is an easy process; all you need is the Integration Kit. Call +1 (970) 245 0408 today for a free consultation to improve the repeatability, accuracy, and productivity of your dispense process.
