  • “Solutions4YOU” – Focusing on Cost and Energy Efficiency At Productronica, Ersa presents many new as well as continuing developments
Oct 28, 2013
 Ersa HOTFLOW 4/08
Ersa HOTFLOW 4/08
Ersa, the specialist for electronic production equipment, has numerous highlights to present to the visitors of Productronica.
Following the motto “Solutions4YOU” the company will exhibit in Munich, on a floor stand of 360 m², the newest models of soldering systems, printers, rework and inspections systems as well as hand soldering tools. In addition to presenting innovative technical solutions, the focus - across the complete range of products and equipment - is on energy efficiency of the equipment and the economical use of resources. Ersa is an enthusiastic member of the VDMA-initiative “Blue Competence” – Engineering a better world! A very welcome engagement of Ersa for the user of their equipment! – You save on cost and you go easy on resources and the environment!
The new HOTFLOW 4 series of systems has been augmented by the Ersa HOTFLOW 4/26.
This system, with a process length of more than 5 meters split into 26 heating zones and 4 cooling zones and characterized by its high energy efficiency, provides a vastly increased throughput while maintaining the customary high process- and soldering quality.
The reduction of operating cost is based on the use of economical and efficient fan motors, which reduce the consumption of power, and on the superior control of the N₂ system, which reduces the consumption of N₂ by 20%. All in all, total energy saving is in the range of 25%.
Also on display is the HOTFLOW 4/08, the shortest reflow system in the series, which provides the same technical features and therefore offers the same reduction in operating costs.
The proven reflow systems of the HOTFLOW 3/14 and HOTFLOW 3/20 series are, on account of their intelligent control systems and because of their low consumption of consumables, known and trusted as excellent all-rounders.
 As the world market leader in the selective soldering technology, Ersa shows the new ECOSELECT 4. This stand-alone system, developed for mid-sized production volumes, can either be manually loaded / unloaded or by transfer to a following system. Flexibility has been designed into the unit, so that the ECOSELECT 4 can be retrofitted at a later date with additional soldering modules.
For users with larger batch sizes, the ECOCELL featuring a dip module and multi-nozzles is shown. Equipped with two solder bath, this unit supports “on the fly” product changes.
High throughput at maximum flexibility is ensured by the VERSAFLOW 3/45, which can be specified with up to 6 mini waves. Whether it is lead-free or leaded solder in mixed operations, or high throughput using different nozzles, the VERSAFLOW series is sufficiently flexible to satisfy all requirements.
The ECOSELECT 1 from Ersa is the system suitable for processing prototypes or small batch sizes. Equipped with the same components as the VERSAFLOW systems, programs written for this system can be transferred to other selective soldering units.
The POWERFLOW N₂ wave soldering system with a conveyor speed of up to 2,5 m/min is now being complemented by the PPOWERFLOW e N₂ for medium production quantities. Both systems are full tunnel units and operate under nitrogen atmospheres.
The automatic rework system HR 600 autonomously performs SMD repairs and impresses by its outstanding price / performance ratio.  The system is shown with the newest software HRSoft 1.2.7. Worth to note is the route Ersa has taken in the repair of QFN’s: With the Dip&Print Station, solder paste is printed onto the component prior to installation. The Dip&Print Station is available for all Ersa Rework Systems. Ersa will demonstrate QFN rework life at is booth.
The ERSASCOPE will be shown with new features: a new, energy saving LED light source provides brighter and more uniform illumination of the solder joint. Also, the newest version of the inspection software ImageDoc will be shown. To detect and document hidden solder defects the user has now the choice between Ersa MOBILE SCOPE, ERSASCOPE 1 and ERSASCOPE 2.
The range of Ersa soldering tools has also grown: with i-Con Vario 2 and i-CON VARIO 4 Ersa presents two high-performance multi-channel soldering and desoldering stations.
A hot air channel with the 200 W powered i-Tool AIR S, as well as 1 resp. 3 additional tool channels which can be operated simultaneously, offer to its user a high degree of flexibility during rework, or producing prototypes and high-quality assemblies.
The extensive range of services of these two new stations as well as practical applications of i-Tool AIR S, i-Tool, Chip Tool VARIO and X-Tool are demonstrated at the booth of Ersa (A4.171), but also as part of the „IPC Hand Soldering Competition“ at the booth of the IPC HSC (A3.318).
May 27, 2022 -
Kurtz Ersa Inc. Announces Upcoming VERSAFLOW 3 Maintenance & Application Training Course Dates
Apr 06, 2022 -
Kurtz Ersa Inc. Hires New North American Director of Sales- Soldering Tools and Equipment
Mar 14, 2022 -
Kurtz Ersa, Inc. Releases New EXOS 10/20 with 600 mm Vacuum Chamber
Feb 25, 2022 -
Kurtz Ersa Inc. to Hold Versaflow 3 Maintenance & Application Training Courses in April
Jan 03, 2022 -
Ersa to introduce IoT Soldering Station, Additive Manufacturing and Selective Soldering Machines at APEX 2022
Nov 17, 2021 -
Kurtz Ersa Inc. Industry 4.0 Solutions Named Best European Product by GLOBAL Technology Awards
Nov 12, 2021 -
Kurtz Ersa Inc. Awarded for Hand Soldering for New IoT Soldering Station, i-CON TRACE
Sep 21, 2021 -
Kurtz Ersa Inc. Announces October Versaflow 3 Maintenance & Application Training Courses
May 26, 2021 -
Kurtz Ersa Inc. Announces Upcoming Versaflow 3 Maintenance & Application Training Course Dates
Mar 19, 2021 -
Ersa Hires New Field Service Engineer in Dallas Area
270 more news from kurtz ersa Corporation »
“Solutions4YOU” – Focusing on Cost and Energy Efficiency At Productronica, Ersa presents many new as well as continuing developments news release has been viewed 661 times
best reflow oven
