  • Closed-Loop, Zero-Discharge PCB Cleaning System in Operation at Manncorp DEMO Center
Sep 28, 2013
Trident XLD, a fully closed-loop, zero-discharge, aqueous cleaning system, capable of removing both water-soluble or rosin-based flux residues, in addition to other contaminants that can impact the long-term reliability of circuit board assemblies
Electronic assemblers in search of a comprehensive, environmentally-safe solution to their PCB cleaning and defluxing needs will want to visit Manncorp’s East Coast Demo Center for a live look at the Trident XLD.  The XLD is a fully closed-loop, zero-discharge, aqueous cleaning system, capable of removing both water-soluble or rosin-based flux residues, in addition to other contaminants that can impact the long-term reliability of circuit board assemblies.
Compatible with a wide range of industry-standard cleaning chemistries, wash solution is automatically mixed, stored, and recovered for re-use in the XLD’s stainless steel wash chamber and plumbing system.  The efficiency of the XLD’s wash solvent recovery system has resulted in a 50 to 90 percent reduction in chemical costs compared to other aqueous cleaning technologies.  During the rinse cycle, de-ionized water replaces the wash solution and a built-in cleanliness monitor detects when the desired resistivity level is achieved.  Twin, counter-rotating, spray bars feature asymmetrical fan-jet nozzles for maximum coverage and penetration into tight areas during both wash and rinse cycles.  In the timed drying cycle, convection and radiant heat remove any residual rinse water from the assembly.
Full cleaning profiles (wash/rinse/dry) are created and stored through a Windows®8 operating system with touchscreen user interface, and a comprehensive Statistical Process Control (SPC) system records alpha/numeric recipe names, process times, temperatures, rinse resistivity levels, and other valuable data.
Trident XLD systems also include the ECO-Cycler Rinse Water Recycling System which captures, filters, and re-deionizes rinse water, eliminating the need for drains, wastewater treatment, or discharge permitting.  The ECO-Cycler also reduces water use, cutting utility costs and protecting a valuable environmental resource.
To learn more about the Trident XLD or other PCB cleaning systems available from Manncorp, please go to http://www.manncorp.com/smt/cat-78-1/PCB-stencil-cleaning-defluxing-machine.html.
May 16, 2014 -
Improved Dip Soldering Systems Have Wider Range of Capability
Mar 25, 2014 -
Android(TM) Operating System Controls New Benchtop Reflow Oven
Jan 30, 2014 -
High-Precision, High-Mix, Print-Place-Reflow Package Under $47K
Jul 27, 2013 -
Manncorp Installs Selective Soldering and Fluxing Systems at Calsonic Kansei Mexicana
Jun 20, 2013 -
Manncorp Opens New Corporate & SMT DEMO Center
Jun 20, 2013 -
Dross Separator Recovers Solder and Saves Money Fast
Feb 08, 2013 -
New High-speed Pick & Place Machine for Nonstop Production of LED Boards
Oct 09, 2012 -
Manncorp Brings High-Precision, Selective Soldering and Fluxing to the Bench-Top with the New ULTIMA Series
Sep 20, 2012 -
Computer-Controlled Batch Reflow With Real-Time Profiling Mimcs Inline Reflow
Jul 31, 2012 -
Batch SMT Assembly & Prototyping Made Efficient, Reliable and Affordable
39 more news from Manncorp »
Closed-Loop, Zero-Discharge PCB Cleaning System in Operation at Manncorp DEMO Center news release has been viewed 999 times
