Some of the characteristics of the Kapton� polyimide tape are:
� It maintains an excellent physical and electrical properties over a wide range of temperature from -269�C (-452�F) to as high as 260�C (500�F)
� It has excellent chemical and radiation resistance
� Standard adhesive type is Silicon
Kapton� polyimide tape can be used:
� As mask in the electronic assembly
� As insulation for traction motor in the automotive industry
� As bar code labels on the PCB processed through wave soldering
� In flexible circuitry
� In nuclear reactors and outer space
Our polyimide tapes are made in the P.R CHINA. Kapton tapes are produced in 1, 2 and 5 mil thickness. Low static products are primarily used in the electronic assembly where static charge is a problem.
Kapton� is a registered trademark of DuPont
we can supply:
1 MIL Tape
2 MIL Tape
3 MIL Tape
Width:0-500 mm
Length: 33 m
Hefei Bajin Trading Co., Ltd.
Tel:0086-551-344-6270, 0086-13805609249, Fax:+86-551-214-2380 ext. 1
Shenzhen Bajin Technical & Development Co., Ltd.
email: shui-muer@126.com http://bajen.51.net
Tel/Fax:0086-755-61289864, 0086-13923788016
