  • Nihon Superior to Showcase Newly Expanded Range of SN100C Soldering Materials at Mexitr�nica 2008
Oct 07, 2008
OSAKA, JAPAN � October 2008 � Nihon Superior USA, a subsidiary of Nihon Superior Co. Ltd., an advanced soldering supplier to the worldwide market, announces that it will feature a newly expanded range of SN100C products, which includes new halogen-free solder paste, in booth 402 at the upcoming Mexitr�nica exhibition, scheduled to take place October 21-23, 2008 at the Expo Guadalajara, Hotel Hilton, in Guadalajara, Jalisco, M�xico.
With its unique tin-copper-nickel-germanium alloy SN100C now firmly established as one of the global electronics industry's most popular lead-free wave soldering alloys, Nihon Superior announces that it is extending the range of material forms in which the alloy is available.
Although developed initially to address the need for an economical wave solder, it has since been found that its properties also make SN100C an ideal choice for reflow and hand soldering as well as spheres for the attachment of area array packages.
The fluidity of SN100C, which is comparable to that of tin-lead, is one of the factors that contributes to excellent through-hole fill and minimal shorts in wave soldering. However, that property is also an advantage in hand soldering where SN100C (040) is the newest eCore addition. It is a high-reliability, halogen-free SN100C (Sn-0.7Cu-0.05Ni+Ge) lead-free flux cored solder wire that does not contain F, Cl, Br or I. The wire features good tip separation and reduced incidents of icicles as well as reduced flux residue cracking, fewer shrinkage defects, reduced copper erosion and a stable intermetallic layer. The wire also provides significant cost advantages.
The 227�C melting point of SN100C was first thought to preclude its use in reflow soldering but when it was noted that tin-silver-copper alloys (such as SAC305 with a melting point of 217-218�C) are typically reflowed with a peak temperature around 245�C it was realized that SN100C could be a -in replacement. Its high fluidity and excellent wetting properties mean that SN100C can be reflowed successfully at a lower superheat above liquidus than SAC alloys. Nihon Superior now offers two types of SN100C solder paste � no-clean ePaste for general reflow purposes and ePaste, a special low voiding paste for critical applications such as die attach in which heat transfer though the joint must be maximized.
The newest ePaste offered by Nihon Superior is the SN100C P600, which is a completely halogen-free SN100C (Sn-0.7Cu-0.05Ni+Ge) lead-free solder paste that does not contain F, Cl, Br or I. It is highly reliable and suitable for high-density assemblies with stable printability, excellent wettability and non-melting reduction. P600 features excellent melting behavior with minimum incidence of solder balling and mid-chip balling, stable printability, and substantial cost advantages. The paste also reduces flux residue, is a compliant alloy for reliability and impact strength (SN100C), and allows a profile similar to that of SAC to be used due to its reflow peak temperature of approximately 240�C.
Advantages of the tin-copper system include its ruggedness in impact loading and the nickel addition provides inhibition of the intermetallic growth that can increase the susceptibility of joints to failure in shock loading, e.g. when a mobile phone is ped. These properties are prompting the industry to evaluate SN100C in flip chip and area array packages, and Nihon Superior is supporting this new application by making a range of eBalls available.
A solution for the lead-free HASL Process, SN100CL features excellent fluidity � good drainage ensures no bridges even on fine-pitch circuitry, good penetration of small diameter holes, uniform coating thickness and a smooth, bright finish. SN100CL wets quickly and offers low copper erosion. SN100CL forms a stable intermetallic compound layer (Cu/Ni/Sn layer) in between solder and copper laminate.
About Nihon Superior Co. Ltd.
Nihon Superior was founded in 1966 when it began marketing unique flux products imported from the US. Since then, the company has made its mark by developing its own soldering materials and supplying them to the electronics industry. On the basis of its expertise in these technologies, Nihon Superior has developed a global business, establishing manufacturing and sales centers in Asia and forming business partnerships with companies in Europe, America and Asia.
Jan 03, 2022 -
Nihon Superior to Highlight TempSave Soldering Materials at IPC APEX
Oct 07, 2021 -
Nihon Superior to Highlight TempSave Soldering Materials and SN100CV P608 Paste at SMTAI
Feb 08, 2021 -
Nihon Superior Receives Honorable Mention in SMTA International Best Paper Awards
Jan 06, 2021 -
Nihon Superior Commemorates 55 Years of Innovation in Soldering Materials
Dec 04, 2020 -
Nihon Superior's Senior Technical Advisor will participate in Low Temperature Solder Panel Discussion
Feb 06, 2020 -
Nihon Superior Receives NPI Award for New TipSave N Flux-Cored Solder Wire
Feb 06, 2020 -
Nihon Superior Wins 2020 IPC APEX EXPO Innovation Award for New Flux-Cored Solder Wire
Jan 06, 2020 -
Nihon Superior to Exhibit TipSave N at APEX 2020
Oct 29, 2019 -
Nihon Superior extends soldering iron tip life by 3X with new TipSave N flux-cored solder wire
Aug 21, 2019 -
SN100C Celebrates 20 Years of Reliability Service
143 more news from Nihon Superior Co., Ltd. »
Nihon Superior to Showcase Newly Expanded Range of SN100C Soldering Materials at Mexitr�nica 2008 news release has been viewed 433 times
Dual Lane Reflow Oven
