  • TORCH vacuum reflow oven appears in China international information and communication exhibition
Dec 16, 2019
Hosted by the ministry of industry and information technology, ciict is one of the largest and most influential ICT events in Asia.
With a history of more than 28 years since 1990, icict has been committed to building the most influential and innovative ICT platform, providing comprehensive services, communication and cooperation opportunities, including policy interpretation, technology research and development, market application and financial investment, for the ICT industry chain.
Because of its cutting-edge, leading, forward-looking and efficient connection, it connects and meets the interests and needs of all parties in the ICT industry chain, and is also known as "the innovation base and vane of ICT market" in China and even the world.
In 2019 (28th) China international exhibition of information communication will continue for the domestic and foreign operators, system integrators and network infrastructure providers, software developers and Internet companies, cloud computing, big data, emergency communication and command scheduling, data center, artificial intelligence, Internet, wisdom, information security, and other enterprises to build city all over Asia the most scale and influence of ICT communication and display platform, development Shared transition, pragmatic promote industrial innovation and cooperation.
Beijing TORCH co., LTD.was invited to participate in this exhibition, and the vacuum reflow soldering equipment will be exhibited on site.
Vacuum reflow welding is also called vacuum welding furnace (vacuum eutectic furnace).
Is in a vacuum environment for high quality welding products, in the process of heating or cooling zhongtong into a reducing gas (N2, formic acid, N2H2, H2), to protect products and solder from oxidation, reduce and solder oxide on the surface of the reaction products at the same time, make the welding surface quality improvement, reduced the rate of welding hollow.
TORCH of vacuum reflow soldering for RS220, this is a specially designed for small batch production, research and development design, functional materials testing of application design of small vacuum reflow soldering equipment, can use different gases (N2, N2 / H295 % / 5%) atmosphere applications, such as used in the chip and the substrate, shell and cover of generating welding defects and perfect the helpless flux welding, such as IGBT, solder paste process, the laser diode packaging technology, hybrid integrated circuit encapsulation, shell plate, MEMS, and vacuum packaging.
TORCH in vacuum reflow welding is becoming more and more mature, which can completely replace the vacuum oven in Germany and the United States.
At present, it has been successfully applied by many famous enterprises in the field of high power laser at home and abroad.
Dec 16, 2019 -
Dec 16, 2019 -
Dec 16, 2019 -
Dec 16, 2019 -
Dec 16, 2019 -
Dec 16, 2019 -
Dec 16, 2019 -
Dec 16, 2019 -
Dec 16, 2019 -
Dec 16, 2019 -
TORCH vacuum reflow oven appears in China international information and communication exhibition news release has been viewed 326 times
