  • Techcon Systems to Showcase Impressive Lineup of Fluid Dispensing Solutions at NEPCON Malaysia 2010
Jun 11, 2010
TS350 Series Advanced Digital Dispenser/Controller
Techcon Systems, a leading global supplier of fluid dispensing systems and accessories, will exhibit an impressive lineup of products with distributor Pacific Advanced Equipment (M) Sdn Bhd, in stand B06 at the upcoming NEPCON Malaysia. The event is scheduled to take place June 15-17, 2010, at the Penang International Sports Arena (PISA).
Techcon Systems TS250 Digital Dispenser/Controller offers an ideal solution for manufacturers in Malaysia, providing an economical, highly accurate and repeatable micro-air dispensing unit. The precision fluid dispensing system includes digital timer and vacuum control for all viscosities of fluids. Packaged ready to use, the TS250 comes with power adapter, air hose, sample tips, barrel and syringe adapter. It is available in two versions of operating pressure ― for general applications 0 to100 psi and for specific low viscosity applications from 0 to 15 psi. The TS250 has a small and highly efficient footprint of just 15.2 x 17.8 x 15.2 cm, with a power voltage adapter of 24V DC, time range of 20 to 60 seconds, and a timed and purge cycle mode.
TS500R Multi-Purpose Digital Controller is the first of its type in the industry and is capable of controlling all of Techcon Systems valve series including: Pneumatic Valves, Spray Valves and Rotary Auger Valves. With a universal power supply, it is a fully “plug and play” system and can be used immediately, anywhere in the world, with its accompanying tools and accessories. This system uses a highly responsive air pressure management system, coupled with a digital timing circuit and display, to provide consistent, repeatable control of all types of valves.
TS5000 Rotary Microvalve uses a rotary feed screw (auger) to dispense fluid with a positive displacement action, allowing for ultra-precise control of the dispensing process. The unique design ensures that material is constantly present at the feed screw inlet, while the controlled rotation of the feed screw moves the material from the feed to the discharge point. Discrete control of the forward and reverse rotations of the feed screw controls the amounts of material discharged.
TS5500 Series Spray Valves are designed for precise spray applications of low to medium viscosity materials. An external stroke control makes it easy to fine-tune fluid flow. Total control of the spray cycle is provided by adjustable fluid flow and precise control of pre-spray, atomizing air and post-spray with the TS500R Valve Controller. Normal maintenance is simple and downtime is virtually eliminated with only one seal to replace.
TS5620 Series Diaphragm Valves are designed to dispense low to medium viscosity materials with precision accuracy over a wide range of shot and bead sizes down to a fraction of a micro liter. A short opening stroke provides fast, positive shut-off. An external stroke control adjustment makes it easy to fine-tune shot sizes. The compact design allows for mounting flexibility and easy integration into automated applications.
Pacific Advanced Equipment will also showcase Techcon Systems TE Dispensing Tips that consist of a stainless-steel cannula with a double helix polypropylene hub. This premium line of dispensing tips is burr-free, and has an electro-polished cannula for unobstructed and consistent material flow. Additionally, they are both silicone- and chloride-free. Other products at the show will include the 700 Series and 400 Series Syringe Barrels.
Finally, visitors to the stand can see Techcon Systems TS1201 Dispensing Pen that is designed to handle a wide variety of fluids – from adhesives and lubricants to sealants and masks, and G-110 Gun, a pneumatic pistol grip gun that provides infinite control of line or dot dispensing and can withstand up to 100 psi (6.9bar) pressure.
For further information, please stop by stand B06 at NEPCON Malaysia 2010 or visit http://www.techconsystems.com.
Techcon Systems was established in 1961 to service industrial manufacturing markets and has continued to be a leader in fluid dispensing systems and products. In 1996, OK International acquired Techcon Systems, providing a strong global sales channel, with direct subsidiaries in France, Germany, Italy, UK, China, and Japan. Today, Techcon represents OK International’s OEM Division of products. Currently focusing on fluid dispensing systems, Techcon’s components are used in medical, automotive, telecommunications, aerospace, and industrial applications worldwide, helping improve manufacturing processes and increase the customers’ bottom lines. Techcon offers an array of fluid dispensing products and provides dispensing components ranging from disposable accessories to complete microprocessor-controlled dispensing systems, and precision valves. For more information, visit the company at http://www.techconsystems.com.
Mar 21, 2022 -
Techcon is pleased to announce the launch of their new TS9800 Series Jet Valve Dispensing System, the fastest dispensing system available.
Jan 29, 2020 -
Get Smarter Dispensing from Techcon at MD&M West
Jan 16, 2020 -
Techcon to Demo New Jet Valve Dispensing System at APEX
Nov 04, 2019 -
Techcon to Demo New Jet Valve Dispensing System at productronica
Oct 21, 2019 -
Techcon introduces the TS9800 Series Jet Valve for improved speed and productivity in electronics manufacturing
Oct 18, 2019 -
Techcon to Demo Smart Dispensing Robots at The ASSEMBLY Show
Aug 22, 2019 -
Techcon Releases Dispenser for Hassle-free Dispensing of 50ml Dual Syringes
Aug 13, 2019 -
Techcon Demonstrates Smart Dispensing Robots at NEPCON Asia
Mar 18, 2019 -
Techcon to Demo Smart Dispensing Robots at productronica China
Jan 05, 2019 -
Techcon Brings Smart Dispensing Robots to APEX
108 more news from Techcon Systems »
Techcon Systems to Showcase Impressive Lineup of Fluid Dispensing Solutions at NEPCON Malaysia 2010 news release has been viewed 918 times
Fluid Dispensers
