  • Test Interface Boards – Customers Appreciate Multitest Pulse Plating Process for Board Fab
Aug 20, 2012
 Multitest, a designer and manufacturer of final test handlers, contactors and load boards used by integrated device manufacturers (IDMs) and final test subcontractors worldwide, announces that its Pulse Plating Process provides significant advantages in terms of fabrication cost and cycle time. Multitest Pulse Plating has been released to manufacturing for all major board customers. The proprietary Multitest process has proven market-leading performance in various customer applications.
Originally the process was developed to support ultra high aspect ratio requirements at 0.4 mm pitch. Multitest has developed a customized plating process for small via diameters in high layer count PCBs used in ATE test. The process allows for .0051" diameter through-holes into PCBs with up to 40 layers.
The Multitest Pulse Plating Process is applied particularly to BGA and WLCSPs but also can be used for vertical probe applications. It eliminates the need for sequential lamination in most 0.4 mm pitch applications. This same technology is deployed for 0.3 mm pitch BGA applications with through-hole construction.
For more information, visit www.multitest.com/pcb.
Multitest (headquartered in Rosenheim, Germany) is one of the world’s leading manufacturers of test equipment for semiconductors. Multitest markets test handlers, contactors, and ATE printed circuit boards. Globally, more than 800 employees serve the company’s customers in offices and branches in North America, Singapore, Malaysia, the Philippines, Taiwan, China and Thailand. For more information, visit www.multitest.com.
Mar 29, 2018 -
Mar 13, 2018 -
Dec 16, 2013 -
Dec 02, 2013 -
Nov 25, 2013 -
Nov 18, 2013 -
Nov 11, 2013 -
Sep 09, 2013 -
Aug 22, 2013 -
Jul 15, 2013 -
Test Interface Boards – Customers Appreciate Multitest Pulse Plating Process for Board Fab news release has been viewed 625 times
Precision Auger Dispense Pump
Fluid Dispensers
