  • Pickering Interfaces to Highlight New PXI and LXI Switching Solutions at the International Test Expo 2017 Preview for ITC – Ft. Worth, TX – October 21 - November 2
Oct 17, 2017
International Test Conference (ITC) 2017.
Pickering Interfaces, a leading provider of signal switching and simulation solutions used in electronic test and verification, will highlight their latest high-density PXI and Ethernet LXI Switching & Simulation Solutions at the International Test Conference (ITC) 2017 in booth 501, in Ft. Worth, including:
High-Density Scalable LXI Ethernet Reed Relay Matrix Solution (model 60-2xx) – Originally designed to test Semiconductors at wafer and package levels, this Reed Relay Matrix solution combines our latest LXI Chassis with our new plug-in matrices. The range comprises four models covering matrices of up to 1,536x4 in increments of 128, 768x8 in increments of 64, 384x16 in increments of 32, and 192x32 in increments of 32.
Users can specify as many or as few plug-ins (up to six) required and can field upgrade the chassis to extend the matrix when necessary. Another important feature is that over 1,500 relays can be closed simultaneously for specific conditions for parametric testing.
These plug-ins also offer built-in scan list sequence stores with triggering capability, providing users with the ability to set a series of up to 200,000 pre-determined sequences on a LXI instrument, the sequences can be triggered by software or one of the sixteen DIO software configurable open collector triggers. They also feature multi-bus capability for parallel testing.
BRIC™ Ultra-High-Density PXI Matrix Modules (model 40-559) – This range of PXI matrices are robust 1Amp/20W switching modules, with up to 4,096 crosspoints. Constructed with Pickering Electronics’ new miniature 4mm x 4mm Reed Relays, these new 1Amp matrices have similar switch densities compared to 0.25Amp, 0.3Amp or 0.5Amp high-density matrix solutions on the market, providing far more robust and reliable switching in the same footprint. The matrices are available in 2, 4, or 8-slot PXI sizes and are designed for high performance matrix requirements. With their high level of switching density, these PXI matrices allow a complete Functional ATE system to be housed in a single 3U PXI chassis and allow the use of much lower cost 8 or 14 slot PXI chassis’.
The 40-559 is available with Y-bus widths of x4, x6, x8, x12 & x16, the three smaller versions having the added versatility of a dual analog bus which allows each BRIC module to be programmatically configured as two totally separate matrices.
The range comes with Pickering’s Built-in Relay Self-Test (BIRST) and is also supported by their eBIRST Switching System Test Tools. These tools provide a quick and simple way of finding relay failures within the modules.
4-slot USB/LXI Modular Chassis (model 60-105) – This chassis complements Pickering’s recently released 2-slot USB/LXI Modular Chassis in that they both offer a small, lightweight form/factor ideal for portable, benchtop and space restrictive applications. These chassis are designed for desk or rack mounting and feature remote control via USB or LXI Ethernet. Remote control over a network enables the switching function of a test system to be located as close as possible to the target equipment. This new 4-slot Chassis supports between one and four Pickering 3U PXI modules. Possible systems include switching matrices up to 2208 crosspoints or up to 72 channels of programmable resistor/sensor simulation.
Both the 2-slot and this new 4-slot chassis are USB 3.0 compatible and have a fully compliant LXI interface. These communications standards enable the chassis to be controlled directly through standard interfaces found on most personal computers and tablets that support HTML5, allowing for a very practical route into a variety of applications in the modular test and measurement market.
Also highlighted will be Pickering’s eBIRST Switching System Test Tools and Switch Path Manager Signal Routing Software. The eBIRST tools were designed specifically for Pickering’s PXI, PCI or LXI (Ethernet) products, they simplify switching system fault-finding by quickly testing the system and graphically identifying the faulty relay. Switch Path Manager signal routing software streamlines signal routing through switching systems and speeds up the development of switching system software.
Alongside Pickering Interfaces in the booth will be their sister company, Pickering Electronics, who will be showing their range of Reed Relays including their new high-density 4mm x 4mm series.
May 20, 2018 -
May 07, 2018 -
May 03, 2018 -
Apr 27, 2018 -
Apr 24, 2018 -
Mar 12, 2018 -
Mar 11, 2018 -
Oct 30, 2017 -
Oct 15, 2017 -
Oct 10, 2017 -
PRESS PREVIEW - Pickering Interfaces to Introduce New PXI and LXI Switching Solutions at productronica 2017
Pickering Interfaces to Highlight New PXI and LXI Switching Solutions at the International Test Expo 2017 Preview for ITC – Ft. Worth, TX – October 21 - November 2 news release has been viewed 651 times
Dual Lane Reflow Oven
