Fuji Releases the Auto Head Cleaner
Mar 28, 2013
Auto Head Cleaner
Auto Head Cleaner
Fuji has just released its newest automation unit, the Auto Head Cleaner. This unit allows you to automatically clean heads offline and can be used to clean any of the rotary placing heads from the NXT and AIMEX series machines.
Head maintenance is essential for ensuring good operation rates and high quality. Using the Auto Head Cleaner allows you to perform this vital work automatically from a simple-to-use menu. You can reduce the work time for cleaning heads by two thirds compared to manual cleaning. This allows you to save labor and time. In addition, by automating this work, you eliminate the variance in cleaning between different operators and get stable cleaning results all the time. Fuji’s easy head exchange system means spare heads can be used to quickly restart production. Meanwhile, the removed head can be cleaned offline. This allows you to maintain a high operation rate for your lines while always keeping them in their best shape.
The Auto Head Cleaner has an inspection function that allows it to automatically determine the cleaning results by measuring the air flow and pressure in heads and checking the timing of the different head axes. The unit also informs operators when it is time to replace the filter in the unit based on its usage and when it is time to replenish the oil supply used for cleaning. This means that the unit always maintains itself in optimum condition.
Specifications
Air cleaning time: 8 minutes
Oil cleaning time: 21 minutes
Oil type: Fluorinated grease (Sumico)
Compatible heads: V12, H12HS(Q), H12S(Q), H12, H08(Q), H08M(Q), H04S, H04
Unit weight: 110 kg
Unit size: 350 (L) x 660 (W) x 1,330 (H) mm (excludes small protuberances)
Jun 18, 2018 -
About the creation of communication standards to enable machine to machine cooperation in SMT lines by ELS
Mar 12, 2018 -
Fuji Participates in “Factory in a box” Group with NXT III
Nov 14, 2017 -
Surface mount technology equipment communication protocol standardization subcommittee’s launch
Mar 16, 2016 -
Fuji welcomes SAKI Corporation to the Fuji Smart Factory members
Mar 16, 2016 -
Fuji Welcomes Koh Young to the Fuji Smart Factory members
Mar 16, 2016 -
Introducing the Fuji Flexible Placement Platform "AIMEX III"
Oct 26, 2015 -
Fuji Machine Manufacturing is pleased to announce its new mounter, AIMEX IIIc
Jun 02, 2015 -
Joint announcement by SPEEDLINE TECHNOLOGIES, INC and FUJI MACHINE MFG. CO., LTD on strategic sales collaboration in Japan
Apr 27, 2015 -
50,000 NXT modules have been shipped
Mar 11, 2015 -
Increased productivity for NXT III machines
16 more news from FUJI CORPORATION »
Fuji Releases the Auto Head Cleaner news release has been viewed 1568 times
Industry 4.0 Reflow Oven
