What's usage of Via tenting for PCB design?
Nov 05, 2019
Via Tenting for PCB Design
Tenting a via refers to covering via with soldermask to enclose or skin over the opening. A via is a hole drilled into the PCB that allows multiple layers on the PCB to be connected to each other. A non tented via is just a via that is not covered with the soldermask layer. Leaving these vias exposed or covered has pros and cons depending on the your design and manufacturing requirements.
Exposed vias on a ground plane and signal paths.
LPI soldermask covered vias to create tented vias.
Soldermask Basics
The soldermask that Headpcb and most pcb fabrication houses use is called a LPI (Liquid PhotoImageable) soldermask. LPI soldermask is usually a two part mixture that is UV curable. It is applied with a screen printing process on to the PCB and then UV cured to a hard finish. Soldermask provides a physical barrier to prevent damage to the PCB copper layers and has a high electrical isolation rating of around 2.5 × 1012 Ω.
Why Would You Want to Cover a Via with Soldermask?
The role of the PCB’s soldermask is to protect the copper traces from damage, oxidation, and solder bridging. These protections also apply to the vias. Tented vias will be more resistant to physical damage and electrical shorts. If your PCB design has through hole components that will be wave soldered then a tented via will prevent the solder from flowing up into the via and over the other side of the PCB where it can potentially short out components. Vias that are also in close proximity to SMT pads should also be tented. This will prevent the solder paste from wicking into the via and creating a poor solder joint. This is especially important with dogbone style BGA escaping.
BGA breakout using via dogbone style routing. Vias are tented to prevent solder paste from flowing into the via.
Reasons for Exposing a Via
Tenting vias does have its downsides. Since the LPI soldermask is a liquid, it has to “bridge” the gap over the via hole. This can cause the soldermask to not completely tent the via leaving a small hole. The small hole can provide a way for corrosive flux, moisture, and other chemicals to enter the via being trapped. This can enable the possibility of a failure of the via due to corrosion eating the copper via. This is less of an issue due to the popularity of no clean flux for SMT assembly but corrosive water clean flux is still prevalent in through hole assembly.
Small via on the left with an unbroken LPI Soldermask which protects the via. Larger via on the right has a broken via tent. This is due to the LPI soldermask’s liquid nature and trying to cover too much of a span.
Leaving the vias exposed without soldermask does not mean the copper will be open to the environment. The exposed vias will be plated by the surface finish of the PCB. At Headpcb we use the ENIG finish which will cover the insides of exposed vias with gold, protecting the copper from corrosion and damage.
For projects that are still in the prototyping phase it can be beneficial to have the vias exposed to be able to fix and reroute traces, and be used as impromptu test points.
Using the Headpcb Platform to Check Via Coverage
The PCB interface on the Headpcb platform provides an easy way to check the vias in your design to see if they are tented or not. Simply upload your design files and check the PCB render. Tented vias will show as just the drill holes with soldermask covering the copper. Exposed vias will have the soldermask pushed back from the annular ring for the via showing the ENIG finish in the PCB render.
How tented vias and exposed vias look in the Headpcb PCB Platform.
Recap
So should you tent your vias, or not? For long term reliability of the PCB, and improved manufacturability of the PCB, it is better to seal the via completely to prevent ingress of moisture and fluids. Doing this economically can be a problem. Filling vias with epoxy and capping (to be explained in a future article!) can be costly. Whether or not tenting a via with LPI soldermask can be done reliably depends on the size of the via. The smaller the via, the easier it is for the via to be filled. After a certain point the vias are too large and tenting can not be done. This tends to be around 15mil diameter for the via with the LPI soldermask used by Headpcb’s PCB manufacture. Vias larger then 15mils should be left exposed so they can be plated with ENIG surface finish instead of relying on the LPI soldermask to seal the via. These larger vias should be kept away from areas with solder paste to prevent paste from wicking away from the pad area. Make sure vias under BGA parts, or vias right next to SMD pads, are tented. When I design boards, I generally leave vias of any size exposed unless they are right next to a SMD pad.
Nov 05, 2019 -
Nov 05, 2019 -
Backdrill
Nov 05, 2019 -
Nov 05, 2019 -
Press-fit Technology
Nov 05, 2019 -
PCB Sideplating
Nov 05, 2019 -
Nov 05, 2019 -
Nov 05, 2019 -
Nov 05, 2019 -
Guideline for wire bonding
Nov 05, 2019 -
8 more news from Headpcb »
What's usage of Via tenting for PCB design? news release has been viewed 237 times
 Reflow System
