PCB Sideplating
Nov 05, 2019
1. The definition of Sideplating
 Sideplating  is actually the metalization of the board edge in PCB filed. Edge plating、Border plated、plated contour、side metal, these words can be used too to describe same function.
2. Sideplating Process
   Drilling - Milling plated Slots - Cleaning -  Copper sink
3. Pictures to show the finished board’s sideplating
4. Possible applications of sideplating:
4.1 Improvement of EMC performance by shielding the inner region of multilayer_s (eg for HF circuit boards
4.2 Cooling function with the edge as additional cooling surface, where an active heat dissipation can be used
4.3 Housing connection
4.4 Board-on-Board connection (see plated half-holes)
5. Design Parameters
To guarantee the producibility of the sideplating, the metallized area must be defined using overlapping copper (copper surface, pads, or tracks) in the CAD layout. Minimum overlap:500mm.
On the connected layer, min 300um of connected copper must be defined.
On non-connected layers, the copper should have gap of min. 800um from the outer contour.
5. Usually , we recommend customers to make immersion gold or immersion silver for edgeplating.  When design the solder mask layer, it should be solder mask opening in the file. Also you can show us some texts to show the detailed requirements.
Nov 05, 2019 -
Nov 05, 2019 -
Backdrill
Nov 05, 2019 -
Nov 05, 2019 -
Press-fit Technology
Nov 05, 2019 -
Nov 05, 2019 -
Nov 05, 2019 -
Nov 05, 2019 -
Guideline for wire bonding
Nov 05, 2019 -
Nov 05, 2019 -
8 more news from Headpcb »
PCB Sideplating news release has been viewed 545 times
