  • Saelig Introduces Isolated USB to RS232/485 Converter Cables With World-Unique Device IDs
Oct 24, 2016
USB-232-K by KK Systems - from Saelig
Powered entirely from USB port using an internal isolated inverter, these converter cables can transmit signals at a data rate of up to 115kbps (USB-485-K) or 230kbps (USB-232-K).  The supplied software drivers support Windows 98, ME, Win2000, WinXP, Vista, Win7, Win8, and Win10 (32 and 64 bit).
Many PCs and laptops today lack serial ports and are required to be used in situations where isolation is required for safety or for operational quality and thus a conventional interface converter cannot be used.  These isolated converters are the solution in these circumstances.  Isolation for both the USB-232-K and USB-485-K is 100% tested to 1500V AC RMS. Female screwlocks are provided on the DB-9 side, making them physically resemble a standard serial port.  All the standard serial handshake lines are supported to allow for maximum compatibility.
The USB-485-K performs automatic driver enable (ADE) automatically, activating the RS485 drive for each transmitted character and eliminating the need for the application software to provide RTS control. This can be overridden by grounding pin 9 of the DB9 connector to permanently enable the drive stage for RS422 (or 4-wire RS485 Master) applications. The USB port provides sufficient power for a full-spec RS422 or RS485 interface capable of driving termination resistors and long cables.
The addition of an optional DB-9-to-XLR cable makes the USB-485-K ideal for use with many professional audio controllers. The USB-485-K converter plugs directly into the USB socket of a PC or laptop and the three pin XLR plug connects to the remote interface port of the controller allowing remote control using the audio equipment’s software.
The USB-232-K and USB-485-K converter cables are produced by KK Systems, Europe’s foremost serial interface manufacturer, and are now available from their USA distributor Saelig Company, Inc. Fairport NY. info@saelig.com.  For detailed specifications, free technical assistance, or additional information,  contact Saelig at (888)-7SAELIG, via email: info@saelig.com, or visit www.saelig.com.
Mar 18, 2022 -
Mar 11, 2022 -
Feb 16, 2021 -
Dec 03, 2020 -
Oct 23, 2020 -
Oct 14, 2020 -
Jun 30, 2020 -
May 28, 2020 -
May 26, 2020 -
May 15, 2020 -
Saelig Introduces Isolated USB to RS232/485 Converter Cables With World-Unique Device IDs news release has been viewed 789 times
Dual Lane Reflow Oven
MSD Dry Cabinets
