PVA, a global expert in dispensing, coating and custom automation, will exhibit at the SMTA Empire Expo & Tech Forum, scheduled to take place Tuesday, April 9, 2019 at the Holiday Inn Syracuse in Liverpool, NY. Company representatives will highlight the MR2 versatile servo-controlled rod dispenser for processing single or dual component chemistries requiring a high level of dosing accuracy.
Utilizing a volumetric displacement concept, the MR2 is capable of processing a wide range of chemistries, including viscous filled or abrasive materials, without concern to slight material changes from batch-to-batch or due to atmospheric conditions. This results in a more accurate dispensing process for difficult to process chemistries.
Utilizing a dual rod system, the MR2 can process 2K materials with mix ratios as wide as 15:1. For 1K chemistries, the MR2 provides the flexibility to alternate metering chambers to greatly reduce refill time, resulting in greater throughput. Each metering chamber is independently controlled, enabling users to easily alter the mix ratio and flow rate in a package mounted directly at the application point.
For more information, please contact PVA at info@pva.net or (518) 371-2684. PVA is a global supplier of conformal coating systems, innovative fluid dispensing solutions and precision valve technology. PVA’s customer driven solutions are utilized worldwide in industries ranging from solar, semiconductor packaging, printed circuit board assembly, medical device manufacturing, and consumer electronics. Throughout the changing global manufacturing landscape, PVA remains committed to providing our customers with exceptional products and industry-leading global support.
