Gen3 Systems Announces Product Lineup for Southern Manufacturing
Feb 02, 2016
ContaminometerTM ,CM22+.
Gen3 Systems Limited, a specialist British manufacturer and distributor, is pleased to announce that it will exhibit in Booth E19 at Southern Manufacturing, scheduled to take place Feb. 9-11, 2016 at FIVE in Farnborough, Hampshire.
The global award-winning Gensonic Stencil Cleaning, system will be displayed with a 24" stencil frame. The system uses a 40kHz on-contact ultrasonic transducer for high efficiency cleaning of stencil apertures. The Gensonic can be used either in conjunction with Gen3 stencil cleaning centres or is portable enough to be taken directly to the printer.
Gen3 also will display the NEW, award-winning contaminometerTM , in particular the CM22+ will be displayed. The CM+ features:
  • Complete testing within only 3 minutes
  • The entire tank volume is re-circulated 6 times every minute (CM33L up to 240 litres per minute)
  • Unique solid gold measuring cell, ballistic amplifier providing a test accuracy of <0.005mS/cm
  • Unique CURVE-FITTING Analysis algorithm (Merit of Fit)
  • Full regeneration in typically < 6 minutes
  • Smooth bubble-free circulation at all times
  • Accurate measurement even when the proportion of test solution to surface area under test are huge
  • Automatic temperature compensation
  • Measures in accordance with all international and MIL specifications old and new
  • New range of PCB/Component handling frames, with integrated draining system.
The CM Series comprises: CM11+, CM22+, CM33+, CM33L+, CM60 and CMBBT.
Also on display, the OPTILLIA HD W30x System is a cost-effective solution for inspection, repair and rework. The W30x-HD deploys cutting edge High Definition live video technology and offers superior resolution, contrast and colour reproduction with its built-in 30x auto focus zoom optics. This macro-inspection camera is ideal for visual examination and quality control of assembled boards, wires, connectors and similar objects.
Alongside Gen3, their Principle, MEK, will be exhibiting the SpectorBOX. Optimised for the inspection of wave and selective soldering of THT & SMT components, SpectorBOX is designed to inspect PCBs inside solder frames directly from the conveyor system. With its totally new mechanical platform, it is the only modular AOI in the market that can be equipped with nine cameras, including an optional Z-axis moveable head to precisely position and focus for varying PCB distance and warpage. The XY drive gantry with ball screw mechanics delivers high-speed inspection while maintaining high accuracy and precision. Specially coated shafts deliver quiet operation and minimize wear to virtually eliminate maintenance and calibration requirements. With its general purpose I/O, SpectorBOX can be simply interfaced with existing or new conveyor systems.
In addition to the above, Gen3 also manufactures conformal coating process equipment – bench-top and in-line systems, and SIR, CAF and solderability testing systems. They also offer a range of test services. The company distributes products for ACE, Finetech, Optilia, Vacunest, Stoelting, Hirox and MBTechFor more information about Gen3 Systems, visit www.gen3systems.com.
Gen3 Systems is a specialist manufacturer of test and measurement equipment used to help predict reliability of electronic circuits and systems in the field. In addition, the company designs and manufactures dip and spray coating process equipment in both in-line and bench-top formats. Gen3 is a specialist distributor for several leading equipment manufacturers including, ACE, FineTech, MBTech, MEK, Hirox, Optilia and, Aprotec Instrumentation, Solder Paste Inspection (SPI) systems.
Gen3 Systems also provides training, equipment and expertise for manufacturers requiring assessment of their electronic products’ reliability. The company also operates a test service and assists with standards development via both the IPC and IEC. Gen3 Systems operates from premises near Farnborough Business Park, on the M3 corridor and just 30 minutes from London’s Heathrow Airport.
May 30, 2022 -
GEN3 provides the solution for Printed Circuit Board Assembly for Stewart Technology Ltd
May 05, 2022 -
Gen3's Dr Chris Hunt, CTO to Present at SMTA Electronics in Harsh Environments Conference
May 05, 2022 -
Mar 23, 2022 -
Gen3 provides key tools for electric vehicles
Mar 23, 2022 -
Jan 25, 2022 -
Gen3 Systems announces product line up for Southern Manufacturing 2022
Mar 09, 2021 -
GEN3 Expansion to Meet Demand
Dec 13, 2018 -
NEW: AutoSIR2 + and AutoCAF2+ Optimising Test Flexibility
Nov 01, 2018 -
Gen3 Systems appoints Emma Hudson as their CTO
33 more news from Gen3 Systems »
Gen3 Systems Announces Product Lineup for Southern Manufacturing news release has been viewed 762 times
Facility Closure
