Vision Engineering Inc., leaders in visual inspection technologies for nearly 60 years, announces a new 360° rotation viewer for the EVO Cam digital microscope. Specifically designed for quality control, testing, inspection and documentation, the rotating viewer for the EVO Cam delivers an oblique view of the subject that can be rotated 360° degrees around a central point, making it ideal for working with engineered, electronic, or precision parts – the fastest, simplest way to inspect all the way around a component without holding it.
Vision Engineering’s 360° rotation viewer combines unprecedented 360° rotating views (up to 105x magnification) with the power and convenience of ultra-sharp full-HD imaging. While obtaining true 3D imagery can only be achieved with a stereo microscope, the new EVO Cam accessory gives the user better understanding of the 3D nature of the subject using 2D digital technology. The result is a simple, efficient and effective digital inspection solution necessary for quality control.
The EVO Cam was designed for exceptional ease of use. The user can seamlessly switch between 360° rotating views to a conventional direct top view. Then, with the touch of a button, capture full-HD images.
Live video streaming and exceptional full-HD 1080p/60fps image quality unlocks the power of digital imaging. EVO Cam has built-in full auto focus capabilities and image capture that can be easily saved to a USB memory stick and displayed on a screen where it is shared with others, without the need for a PC.
In-built LED ringlight illumination provides optimum illumination at all times and the wide range of high quality stand options allow EVO Cam to be configured to suit a wide variety of work environments.
Vision Engineering’s latest addition to its leading range of optical inspection solutions provides stunning clarity with ultimate simplicity.
