Multiply by six the capacity of your soldering station
Oct 28, 2016
Connect five PSE Power Supply Units to a single DME and work with up to 24 tools simultaneously.
JBC, a leading manufacturer of soldering and rework equipment, has increased the capacity of its DME station, which can manage up to 4 tools simultaneously and is fully compatible with most JBC tools.
Now you can also centralize your control of five PSE 4-Tool Power Supply Units in a single DME. This means you can work with up to 24 tools at the same time.
This network allows you to manage a complete working area from a station and thereby increase your production and cut costs.
To get started, you only have to update your DME software.
Guarantee quality with the new PSE
The new PSE unit can handle up to 4 tools simultaneously and has no interface. With this unit you can personalize over 20 parameters, such as the language, and ensure that these settings cannot be modified during the work process, which guarantees your quality.
You can manage and monitor the station using a PC or a robot. It can also be connected to the B·Net system via USB-B or LAN (Ethernet) so it can be controlled remotely.
You can also connect the ports to peripherals, which means each tool can work with a module and a pedal at the same time.
The 4 LEDs on the front panel of the station indicate if the ports are connected and what the tool’s status is (in Work or Sleep mode).
Jan 31, 2017 -
Effective protection for PCBs while desoldering
Jan 24, 2017 -
JBC expands its distributor network with Flexible Assembly & Technimark
Jan 24, 2017 -
JBC extends its cartridge range with new models
Sep 14, 2016 -
JBC will present the Web Manager at the SMTA International 2016
Jul 19, 2016 -
Guaranteed quality with the new PSE Power Supply Unit
May 20, 2016 -
Tinning wires and components faster and safer
Apr 22, 2016 -
JBC is sponsoring the IPC Hand Soldering Competition at the SMT show
Apr 01, 2016 -
JBC renovates its manual solder feed iron
Multiply by six the capacity of your soldering station news release has been viewed 550 times
