Optical Connectivity Secures Gaming and Multimedia Streaming
Oct 29, 2020
Optical connectivity provides user experience for online gaming and multimedia streaming (copyright: Shutterstock)
Carlos Pardo is CEO and Co-Founder of KDPOF
KDPOF Study Reports Significant Effect of Home Networking on Online Gaming Experience
KDPOF, leading supplier for gigabit connectivity over fiber optics, has conducted a study examining the influence of home networking on online gaming and video streaming. For online gaming, the delay between an action the player intends to perform in the game and its actual effect on the screen can totally ruin the experience. Among gamers, this latency is known as ping or lag. The action issued by the player has to go through different network segments until it reaches the game server; it is then processed and the response travels back to the gamer. Numbers over 150 ms are a total no-go experience while being under 20 ms is considered a very good behavior. “There are three main segments that can influence the latency level: online game servers, access network, and home networking,” explained Carlos Pardo, CEO and Co-founder of KDPOF. “Our study showed that the home network plays a key role in the whole experience. Average values as low as 1 ms and up to 30 ms could be found.” A good solution is wired connectivity over plastic optical fiber (POF). It provides very low latency and jitter, just like Ethernet wiring but without visible cabling installed.
The Importance of Low Latency for Home Networks
The number one home network technology used nowadays in any home is Wi-Fi. Unfortunately, it provides little control over when each node has access to the air. Any packet loss is not noticeable for services such as web browsing, but when delivering video related services, these crashes generate peaks of latency. Those packets need to be retransmitted, extending the time required to reach the other end. If a device in the same environment is connected over Ethernet directly to the access router, the picture changes significantly. “It is not surprising that gamers prefer to connect over wires rather than Wi-Fi due to these effects,” added Carlos Pardo. “Delays are getting even worse with the rapid increase of multiple Wi-Fi access points of Wi-Fi mesh in the home.”
Plastic Optical Fiber Combined with Wi-Fi
Since wired connectivity adds only negligible latency to the path, it is recommended over wireless for the in-home portion. With its ease of installation, lack of aesthetic impact, robustness, and stability, plastic optical fiber is the ideal solution to contribute to a perfect online gaming experience. The ultimate home network solution is one that combines the advantages of a POF backbone with Wi-Fi access points throughout the home. It secures 1 Gb/s speed to each access point, avoiding any loss inherently present with wireless due to distance, walls or interference. While Wi-Fi links provide latencies on the level of milliseconds, POF is on the level of microseconds, i.e. 1000 times better.
POF can easily be installed in any duct throughout the home: power, coaxial, or telephone conduits, or easily hidden on walls, under carpets or through false ceilings. Devices that connect to the network via Wi-Fi will continue to use that connection, but will enjoy the dedicated 1 Gb/s speed of the POF network. This way, Wi-Fi speed experienced anywhere in the home is the same as next to the router.
May 03, 2022 -
KDPOF Complements Renesas' New Vehicle Computer VC4
Apr 08, 2022 -
Proposed IEEE Optical Multi-gigabit Automotive Standard Achieves Milestone
Dec 09, 2021 -
Funzin Integrates KDPOF ICs in New Devices "FAIP 3.0" and "Photon"
Sep 14, 2021 -
System Solution for Optical Communications in Vehicles
May 11, 2021 -
EVK9351AUT Accelerates Project Launch for Optical Gigabit Connectivity
Mar 10, 2021 -
New KD9351 FOT Reduces Cost for Gigabit Connectivity
Aug 25, 2020 -
Aukua Systems and KDPOF Team up for ISO 21111 Standardization
Aug 12, 2020 -
Granite River Labs and KDPOF Collaborate to Deliver ISO-Standardized Automotive Ethernet Over Plastic Optical Fiber
Jul 30, 2020 -
ISO 21111 Complements IEEE Std 802.3bv™ for Overall Standardization of Optical Gigabit Connectivity
Jan 15, 2020 -
KDPOF Demos First 25 Gb/s Automotive-grade Optical Network
10 more news from KDPOF »
Optical Connectivity Secures Gaming and Multimedia Streaming news release has been viewed 254 times
Capillary Underfill process
