KDPOF Presents New KD7051 PHY for Automotive Networking
Nov 18, 2020
New KD7051 transceiver by KDPOF for automotive networking convinces with reduced cost and footprint  (Image: GettyImages)
Cost and Size Reduction by Integrating Transceiver IC, Optoelectronics, and Optics into One Fiber Optic Transceiver
KDPOF, leading supplier for gigabit connectivity over fiber optics, presents the brand new integrated Fiber Optic Transceiver (FOT) KD7051. It is the first device for optical in-vehicle connectivity that incorporates the transceiver IC, optoelectronics, and optics. The integrated FOT is a 100 Mb/s optical port in one single component. “By constructing the ASIC IC, photodiode and LED as one single device, we significantly reduce cost and footprint for automotive Ethernet connectivity at 100 Mb/s,” stated Carlos Pardo, CEO and Co-Founder of KDPOF. “The decreased number of parts also reduces the effort in testing and qualification.” KDPOF’s new KD7051 thus substantially reduces the overall expense compared to STP (shielded twisted pair of copper wires). Further advantages are no margin stacking between links in the supply chain and supply chain simplification. Consequently, it offers competitive pricing for EMC critical or galvanic isolated critical links. Applications include battery management systems, camera and sensor links, fast Ethernet links and smart antenna links.
All New Physical Layer
KDPOF’s new transceiver IC KD7051 offers a complete new FOT design. It reuses low cost MEMs encapsulation and allows SMD reflow assembly with 8 by 7 mm LGA components. The FOT is fully shielded against electromagnetic radiation. Fiber connection is done with a very simple plastic connector placed on top. The temperature range, from -40 °C to +105 °C, conforms with harsh automotive environmental requirements. With a vibration class of V2, it withstands motor conditions. Additionally, the device endures water without sealing. EMC performance is excellent even with the ECU shield case removed, as shielding is integrated into the PCB component. The assembly of the FOT and the IC in the PCB is simplified. Optics implement Tx and Rx lenses. The first prototypes are available.
Simple Implementation
As a plastic optical fiber with a large diameter, POF is more cost-effective to manufacture and install: installation is just easy plug and play; winding and clamping is similar to copper cables. Moreover, during the car assembly, the optical harness can be installed in the same process as the copper harness. POF has been present in vehicles for more than 10 years and is installed in millions of cars.
Aug 28, 2019 -
Battery Management System with Optical Connectivity Ready for Production
Feb 08, 2019 -
Optical Network Is Ready for Future Wire Harness Architectures
Jan 11, 2019 -
Galvanic Isolation Secures New 48-volt Electrical Architectures
Jan 08, 2019 -
KDPOF Automotive Optical Gigabit Ethernet Receives Compliance Approval from Premier Japanese Automotive Industry Body
Mar 29, 2017 -
Optical Gigabit Ethernet Becomes IEEE Standard
KDPOF Presents New KD7051 PHY for Automotive Networking news release has been viewed 424 times
Fluid Dispensers
