Climatest Symor launched the new fast dehumidifying dry cabinets,the moisture can lower to <5%RH within 30 minutes(unload,ambient 25C,60%RH)
. The whole cabinet adopts 1.2mm galvanized steel with Dupont baking varnish,which is strong corrosion resistant, 3.2mm high intensity toughened glass.reinforced structure,excellent load-bearing and sealing performance.
. It adopts US import Honeywell humidity sensor; temperature and humidity can be independently displayed,with memory function,no longer to reset humidity after power failure.
. Symor pass RoHS to claim our cabinets don’t pollute electronics.
. Zinc alloy lock with perfect air tightness and anti-theft function.
. Front two ESD casters with brakes for easy move and ESD stand.
. With Black color (ESD models) or White color(non ESD models)
