Lamp
May 31, 2021
Replacement Lamp
A replacement lamp is the replacement of a certain model of projector. For every given projector model, there are several replacement lamps that will work for the projector, but each of the options had differences that may be important for some buyers. There are multiple options of replacement lamp to purchase. The first option to purchase it 100% OEM module, where it is the same bulb and cage that was in the projector when it was new. OEM modules are sourced by reseller distributors directly from the projector manufacturer. When a buyer does not want to risk any compromise of the projected image quality or lamp life compared to what new projector provided out of the box.
The second option to purchase is a hybrid module with an OEM bulb. A hybrid module with an OEM module is the closest option to the OEM module. The bulb in this case is the exact same one that was in the new projector, but the cage has been re-manufactured to be compatible with the projector. The only risk factor is in the re-manufacturing of the cage, precise fit and quality electrical connections. The next option is a hybrid module with a premium bulb. The premium bulb is the bulb with the same specification as the OEM bulb but made by one of the other bulb manufacturers, not the same manufacturer that made the OEM bulb.
The last option is the compatible module. It is the ultralow cost replacement lamp modules that can be found online. The bulb is a “copy” or “knock-off” bulb made by a secondary manufacturer. These low-cost compatible modules produce compromised image quality and significantly lower lamp life than the other options. In some situation, the compatible modules might be a reasonable choice, such as when you need the old projector to work for a few months.
Replacement Lamp is available through Quick Time Engineering Inc.
Jun 04, 2021 -
Vibration Monitoring
Jun 04, 2021 -
Valves, Fittings & Tubbing
Jun 03, 2021 -
Valve Controllers
Jun 03, 2021 -
Turbine Parts
Jun 03, 2021 -
Transmitter
Jun 03, 2021 -
Transducer
Jun 03, 2021 -
Thermostat
Jun 03, 2021 -
Thermocouple
Jun 02, 2021 -
Solenoid Valve
Jun 02, 2021 -
Soft Starter
Lamp news release has been viewed 194 times
Jetting Pump for Integration
