  • New Yorker Electronics Introduces New Family of ECE Flex Cable Connectors
Dec 18, 2020
New Yorker Electronics to Distribute new Excel Cell ZIF Type Board-to-FPC Connectors series with 0.5mm pitch/contact spacing in Slide SMT Type and Flip-Lock Rotary Cover Type
New Excel Cell Electronic ZIF Type Board-to-FPC Connectors are used in Medical Ventilators, Computers, and Security Applications
NORTHVALE, New Jersey, USA – New Yorker Electronics has just released new ZIF Type Board-to-FPC Connectors series with 0.5mm pitch/contact spacing in Slide SMT Type and Flip-Lock Rotary Cover Type from Excel Cell Electronic (ECE). Available in embossed type for automatic mounting, they are commonly used in medical ventilators, computers, headphones, security equipment applications.
The EFC-PT24 Series (SU/SD/S) Flex Cable Connectors are 4~60-pin slide SMT types. They are offered in a 0.5mm pitch and are available in different contact configurations: Slide Type up-side contact, Slide Type down-side contact and Slide Type, vertical. They are available in tube or embossed style.
The Excel Cell EFC-PT24 Series (RF/RD) is designed with 0.5mm Contact Spacing. They too are ZIF Type Board-to-FPC Slide SMT Connectors but in a flip-lock (rotary cover) type. These 4~50-pin slide connectors are SMT types are available in Rotate Type, Sunk-into PCB and Rotate Type, on-PCB configurations.
Both series have a dielectric withstanding voltage of 250VAC RMS, a contact resistance of 20mΩ max. (initial), 40mΩ max. (final) and withstands an operating temperature of -40°C ~ +85°C. Through franchise distributor New Yorker Electronics, ECE can supply a complete cable assembly with an FPC Wire Thickness of 0.30mm if needed.
Features & Benefits:
  • Voltage rating: 50V per contact
  • Connector Heights: 1.85mm to 2.0 mm
  • Durability: Mate & Un-mate with applicability for 20 times, Contact resistance: 40mΩ max.
  • Current rating: 0.5A (per contact)
  • Dielectric Withstanding Voltage: 250VAC RMS
Applications:
  • Medical Ventilators
  • Computers
  • Headphones
  • Security Equipment
Excel Cell Electronic manufactures high-precision electronics components, creating lead frames of semiconductors for discrete devices. ECE applications include signals, voltage regulation, voltage amplification, switch and other functions as well as photoelectric products for signals, lighting products/components with either visible or invisible light. ECE also manufactures all kinds of optical and LED products. As a franchise distributor ECE, New Yorker supplies its full line of Dip and Micro Switches, Connectors, Terminal Blocks, Relays, Chip Inductors, Chip Beads, Resettable Fuses and Optoelectronics.
Jun 08, 2022 -
Jun 02, 2022 -
May 28, 2022 -
May 28, 2022 -
May 23, 2022 -
May 16, 2022 -
May 05, 2022 -
May 05, 2022 -
Apr 27, 2022 -
Apr 06, 2022 -
New Yorker Electronics Introduces New Family of ECE Flex Cable Connectors news release has been viewed 283 times
Dual Lane Reflow Oven
