  • Orion Reversible Flow Fans Feature Directional Flow and Speed Control in One Unit
May 05, 2022
New Yorker Electronics Supplies Orion Fans' new IP68 microcontroller-based Reversible Flow Fans
NYE now Supplying Microcontroller-based Designs that Provide Directional Flow and Speed Control in a Single Fan
NORTHVALE, New Jersey, USA – New Yorker Electronics has announced Orion Fans’ release of its new series of microcontroller-based, Reversible Flow Fans rated up to IP68. By utilizing PWM signals to control fan speed, these fans provide a solution for difficult cooling requirements. Fan speed and airflow direction control can now be achieved with one fan without supplementing excess wires or circuitry.
Previously, two fans were required if the designer wanted to achieve two directions of airflow. This arrangement added cost to the bill of materials, required more area in the design to accommodate both fans, increased maintenance requirements, and lowered product reliability.
Orion Fans’ Reversible Flow Fans are a specialty design that enables some unique uses:
  • Outdoor applications where the device intakes air in one direction, but a periodic reverse flow ensures air pathways do not become clogged with environmental debris
  • Equipment where seasonal environmental changes require different airflow of intaking versus exhausting air
  • Situations where a “confidence check” is needed to confirm the proper operation of airflow monitoring sensors
  • Applications where dynamic control of airflow pathways is needed, and large airflow check valves may be difficult or impossible to integrate
  • HVAC applications where occasional intake of environmental air is required to comply with building codes
  • Other applications include vending machines, cooler display cases and lighting
“By utilizing the newest microcontroller-based designs in the reversible flow fans, we provide engineers the advantage of both directional flow and speed control in a single fan, a feature that we have been receiving more and more requests for,” says David Luna, VP of Marketing for Orion Fans.
In typical fan speed control, PWM control provides a fixed-frequency AC square wave signal to the fan, and the duty cycle of the waveform is altered to match the desired speed. Reversible fans extend this control paradigm by segmenting the PWM duty cycle curve into “Forward” versus “Reverse” regions. This segmentation still allows for speed control over a condensed duty cycle range, while enabling control of the direction of flow without requiring additional control wires or circuitry. In most cases, a simple firmware or software change in the customer’s equipment facilitates direction control with minimal disruption of industry standard control assumptions.
Features & Benefits:
  • One fan to achieve airflow direction and speed
  • Periodic reverse flow ensures no clogging
  • Remotely controls building airflow intake and exhaust
  • Reduces cost and space of two fans
Applications:
  • Outdoor / Seasonal Equipment
  • Telecom Enclosures
  • HVAC
  • Vending machines, cooler displays
  • Lighting
The reversible flow fans are currently available in 120mm and 172mm packages, in 12V, 24V, 48V and 60V versions. Orion Fans, a division of Knight Electronics, Inc. is an ISO9001/20015 global manufacturer of standard and custom AC and DC fans, fan accessories, fan trays and blowers that are distributed by New Yorker Electronics. Established in 1995, Orion Fans has engineering and manufacturing facilities in the United States, Europe, and Asia.
About New Yorker Electronics
Headquartered in Northvale, NJ, New Yorker Electronics, Co., Inc. (www.newyorkerelectronics.com) is a global franchised distributor of electronic components, value-added services, and supply chain solutions to the world’s leading OEMs and contract manufacturers in various markets. Founded in 1948, the AS9120B and ISO 9001:2015 certified company has earned a reputation for delivering superior levels of reliability and customer support while providing direct franchise access to an extensive ready-to-ship inventory of passive, interconnect, electromechanical and Mil-Spec components, as well as semiconductor devices.
Jun 08, 2022 -
Jun 02, 2022 -
May 28, 2022 -
May 28, 2022 -
May 23, 2022 -
May 16, 2022 -
May 05, 2022 -
Apr 27, 2022 -
Apr 06, 2022 -
Mar 08, 2022 -
Omni Pro Electronics Announces Availability of Adam Tech's Ultra-High Speed Cable/Connector Assembly
Orion Reversible Flow Fans Feature Directional Flow and Speed Control in One Unit news release has been viewed 125 times
