  • Pneumatic Fixture Cleaning Machine HJS-6600,Fixture Cleaning Machine
May 12, 2022
Product Description:
 Compressed Air Driven 1000mm Diameter Round Basket Reflow Oven Flux Cooler And Filter Cleaning Machine.
 Pneumatic control, powerful cleaning ability, easy operation, easy maintenance.
 Air pumps, air motor, mechanical meters, mechanical valves.
 HJS-6600 Compressed Air Driven 1000mm Diameter Round Basket Reflow Oven Flux Cooler And Filter Cleaning Machine. is used to clean flux on reflow oven coolers and filters.... It is a pneumatic cleaning machine, not use electric power. Both solvent and water based liquid can be used in this machine. Very easy to operate and maintenance.
Machine Features:
1. Pneumatic control, no use electric power at all, absolutely safe.
2. SUS 304 machine structure, resist Acid and Alkali corrosion, firm and attractive.
3. One-button easy operation, high pressure clean+ high pressure rinse+ compressed air dry, all process complete in one time automatically.
4. Closed-loop clean and rinse, clean solvent and rinse solvent is filtered in the machine
5. Solvent recycled to use to make cost down.
6. Both solvent and water-based liquid can be used.
7. Non-contact clean, protect cooler
8. Standard equipped with auto fill-in and drain-out function.
9. Inner lock safety design, once door open, the machine stops immediately.
Machine Spec:
Item
HJS-6600
Cleaning basket size
Φ1000 x H 200(mm)
Clean spray unit
Upper/Lower/front side, all-round spray,   basket rotate
2-level filter
1mm/20um filter
Clean time
5~15 Min
Rinse time
1~2 Min
Air dry time
5~10min
Clean tank capacity
80L
Rinse tank capacity
80L
Clean spray pressure
2~4kg/cm2
Air supply
0.5~0.7Mpa,800~1000L/min
Machine size
L1450 x W1550 x H 1400 (mm)
Machine weight
400KG
Customer questions and Answers:
Q1: Is HJS-6600 safe?
A1: Yes, HJS-6600 do not use electric power, only compressed-air, so no risk of electricity, heat, sparks.
Q2: How HJS-6600 clean products?
A2: The products put on round basket, the upper and lower spray rods spray solvent while basket turns at low speed.
Cleaning comparison pictures before and after cleaning:
Jun 26, 2022 -
Pneumatic Fixture Cleaning Machine HJS-6600,Fixture Cleaning Machine news release has been viewed 111 times
