  • Online PCBA Cleaning Machine HJS-8100,Online PCBA Cleaning Machine Spray
May 25, 2022
Product Description
HJS-8100 is a 600mm Width Stainless Steel Net Transportation Batch PCBA On Line Cleaning Machine .
HJS-8100 is a high quality and powerful PCBA in line cleaning machine for batch PCBA.
HJS-8100 is on line, high spray pressure, longer liquid wash section, long DI water rinse, long hot air dry automatic cleaning machine.
HJS-8100 is a powerful PCBA cleaning machine which can clean flux residuals, solder balls and particles on assembly PCBA, such as: rosin flux, water-soluble flux, non-clean flux, solder paste and other organic and inorganic contaminations.
Powerful process: Pre-wash+Wash1+ Wash2+Chemical isolation+ Pre-rinse+ Rinse+Final rinse+ Air blow dry+ Hot air dry1+ Hot air dry2. It can use to clean almost all kinds of PCBA.
Machine advantages:
1. Big quantity PCBA in line cleaning system.
2. large amount liquid spray wash method, super wash result. Thoroughly clean water-sular solder paste flux and non-clean solder paste flux on SMT or THT PCBA after welding.
3. Wash sections + DI water rinse section+ Air blow section +2 hot air dry sections.
6. Liquid and DI water spray pressure can be adjusted for different PCBA cleaning requirements.
Customer Question & Answer
Q1: Why HJS-8100 can clean all PCBAs?
A1: HJS-8100 is a 6600mm long machine, it has 2x600mm powerful and heavy flow wash section with 2x14 spray rods. that's why it is so powerful.
Q2: Why is it 150KW?
A2: in wash section, it has 3x12KW heater; in pre-rinse section, it has 1x12KW heater; in Rinse section, it has 3x12KW heater; in hot air dry section, it has 2x7.5KW heater, and we also have air blowers, electric pumps.
A4: It depends on liquid itself and temperature, we install liquid cool condenser, normally 5~15L/ Hour.
Jun 26, 2022 -
Online PCBA Cleaning Machine HJS-8100,Online PCBA Cleaning Machine Spray news release has been viewed 87 times
Benchtop Fluid Dispenser
