  • Semiconductor Spray Cleaning Machine HJS-9700,Semiconductor Wafer Cleaning Machine HJS-9700
Jul 05, 2022
Product Description
As a SEMI SIP packaging in line auto cleaning system for advanced semiconductor package process. HJS-9700 is precise, high quality, SIP packaging deflux cleaning system.
HJS-9700 SIP package auto cleaning machine is used to clean flux residuals, solder balls and particles on sip package products, such as: rosin flux, water-soluble flux , non-clean flux ,solder paste and other organic and inorganic contaminations.
Precise process: Pre-wash+Wash1+Wash2+ Chemical isolation+ Pre-rinse+ Rinse+Final rinse+ Air blow dry+ Hot air dry1+ Hot air dry2.
By using our latest mix spray cleaning technology, the system has following advantages:
1. SIP package semi in line cleaning system.
2. Liquid mix spray wash technology, super wash result, thoroughly clean water-sular solder paste flux and non-clean flux.
3. Longer wash sections + DI water rinse section+ Air blow section +2 hot air dry sections.
6. Liquid and DI water spray pressure can be adjusted for different semiconductor products cleaning requirements.
Customer Question & Answer
Q1: What kind of semiconductor products can HJS-9700 clean?
A1: Flux on SIP, BGA, CSP, Flip chip... package. it has 2x600mm wash section with 2x14 spray rods on it, that's why it is so powerful.
Q2: Why is it 150KW?
A2: in wash section, it has 3x12KW heater; in pre-rinse section, it has 1x12KW heater; in Rinse section, it has 3x12KW heater; in hot air dry section, it has 2x7.5KW heater, and we also have air blowers, electric pumps.
A4: It depends on liquid itself and temperature, we install liquid cool condenser, normally 5~15L/ Hour.
SIP package picture
Jun 26, 2022 -
Jun 25, 2022 -
SMT Spare Parts and Feeders
